Question about T-Mobile Dash Smartphone
Signal issues when i walk around my phone goes into searching mode trying to find a signal for over 30 minutes.
  • gooberton8 Aug 27, 2008
    I am having the exact same problem. When I try to search for a network manually, it says there are no networks available, which I know is untrue.
  • cecilelaforc Sep 20, 2008
    My Samsung t-mobile has had the same problem for almost two weeks. I put the airplane mode ON, then took it OFF and it's never been the same.
My phone won't read my sim card
Posted on Aug 27, 2008
  • 1,183 Answers
I apologize , i guess the chat has gor disconnected.
Under network selction , select manual, and the tap on the set network tab. Once that done , select the T-mobile network and if it below other networks move it towards the very top
click ok once this is done
This is HTC support number for t-mobile , T-Mobile 1-888-356-2375
Its a toll free number , you can get second advice from them as well
Posted on Aug 08, 2008
  • Mandeep  Singh
    Mandeep Singh Aug 15, 2008
    Were you able to get the problem resolved ?
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
Make sure that on your cellular has a bluetooth capability, make sure that it is in pairing mode or listening or searching mode only then will your car stereo be able to search for the signal from your phone. There are two ways usually your phone will transmit and your stereo sill listen to the signal or the other way around.
May 18, 2011 | Kenwood Kca-bt300
Motorola z3 searching for network issue
I would suggest getting her a new phone because now of days all the phones are made poorly
May 12, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Turn the phone on and wait a few seconds (30) just in case something is booting up.
With the phone still on pull the battery out.
Wait a few seconds (15) and install battery.
Turn on the phone and walk away for 5 minutes to make sure the phone has time to do whatever it needs. I found this issue working with Blackberries, you have to give it time...
Dec 29, 2009 | Motorola Lands Phones
Phone won't recieve signal
Try to power cycle the phone by removing the battery for a minute then place it back in, try to check if there is a signal on the phone. If it keeps on having the same issues you need to call your service provider for network related issues.
Jul 31, 2009 | Cell Phones
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Apr 03, 2009 | 2000 Lincoln Navigator
    No network Coverage
    Set your network to the default one. It might just be the area you are in. There might be something interfering with the signal. If you are in an office or other type of building they might have put in a field on the roof so you cant get signal. try walking around
    Feb 24, 2009 | Nokia 6263 Cellular Phone
    Try setting the network lookup to manual instead of automatic. That way it would only look for a signal when you want it to.
    Oct 14, 2008 | Kyocera Switchback KX21 Cellular Phone
    My samsung upstage phone is stuck in offline mode
    Has the phone been dropped or gotten wet? If you look at the antenna area are there any cracks in the housing? If any of these are true you may have a bad connection between the antenna and the main board of the phone. If you can see any cracks in the housing i would recommend taking it to the shop for repair. Its not too expensive a repair usually around 30 to 40 dollars. If you need any help let me know!
    Jan 11, 2008 | Samsung SCH-a670
    T-Mobile Dash Smartphone Logo
    112 people viewed this question
    Top T-Mobile Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Martin Murray
    Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
