FixYa.com
Tags:
IBM Token-Ring 16/4  Print Server
5.0.2 enterprise and IBM Token-ring problem
By Horner - usenet poster
I have a PCI 486 (adaptec 2940 scsi) with 3.2 4.2 and tcp/ip connected to
an IBM AS400 using an IBM ISA 4/16 shared RAM token ring adapter, and it
works fine.
Now I am replacing it with a Pentium Machine, dual 2940, but It have
several problems.
I moved the Network board to the new machine and it is regularly recognized
by o.s. but
even making a simple ping after 300 to 500 loop it hangs.
What is trange is that if you leave the system for some time (for example 1
hour) the ping works again for a little.
I cannot determine if is a SCO problem or a motherboard problem.
PLEASE HELP!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Cato
Cato - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <01bc03b6$594ed100$c9a09384@co­lanzi>, cola @micronet.it says...
 >I have a PCI 486 (adaptec 2940 scsi) with 3.2 4.2 and tcp/ip connected to
 >an IBM AS400 using an IBM ISA 4/16 shared RAM token ring adapter, and it
 >works fine.
 >Now I am replacing it with a Pentium Machine, dual 2940, but It have
 >several problems.
 >I moved the Network board to the new machine and it is regularly recognized
 >by o.s. but
 >even making a simple ping after 300 to 500 loop it hangs.
 >What is trange is that if you leave the system for some time (for example 1
 >hour) the ping works again for a little.
 >I cannot determine if is a SCO problem or a motherboard problem.
 >PLEASE HELP!
Hi !
Following our recent conversation, I suggested to you to
try the AHS 5.2 (the one bundled with the CD) and to
give the patch OSS 449a a try. Have you tried 'em ?
Did you notice any changes ? I know this might sound
obvious but did you try by changing the network
adapter ? Also, try to strip the system to the minimum
(remove the Stallion board, the tape and everything
not strictly related to the system functionality) and try
to perform the same tests which raised the problem.
Hope this helps !
Best,
Roberto
Roberto Zini                                  email : f @strhold.it
Strhold Sistemi EDP
Reggio Emilia      ITALY
"Has anybody seen an aircraft carrier around ?"
        (Pete "Maverick" Mitchell - Top Gun)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
colanzi's CPU sent forth this bytestream:
| Please Help!
Help what?
Jean-Pierre Radley   j @jpr.com   XC/XT Custodian   Sysop, CompuServe SCOForum
Solution #3
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
We had similar problems on one of our internal networks. It
turned out to be a faulty BNC connector. Make sure your
cable and connectors are sound and that the cards are configured
for the correct cable type (some are switchable).
-Dave
Solution #4
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Please Help!
Solution #5
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
davi @sco.com scritto nell'articolo <32DF80B3.6 @sco.com>...
Thanks for reply.
I am shure of cable and Network board becouse I moved back to the old
System and
it works. By the way Token Ring is not Ethernet, and has no BNC, but
strange IBM connectors to a box like a hub, and a standard DB9 to the
board.
Thank you.
Bye.
Can you Help with these Print Servers problems?
Print Servers
Axis print server losing...
I am troubleshooting an axis... Answer This...
Print Servers
Assembly Instructions
Looking for assembly... Answer This...
Print Servers
Internal Zebra Print Server
I want to connect Zebra Printer... Answer This...
Print Servers
sharp copier
light blink 1 then L will not... Answer This...
Print Servers
sharp copy machine
will not copy runs for a few... Answer This...
Repair Service
Find Print Server Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
