Question about Kenwood Audio Players & Recorders
I have a Kenwood Audio Video Surround Receiver and some of the sound effects are no longer working properly. The sound on these effects comes out crackly/muffled.
    Scholar:
  • 144 Answers
Assuming they did sound correct there are some possibilities:
your wiring, if you live a humid area it might be that your wires are a bit corroded at either the speakerterminal or at the receiver terminal. Simply cut of the corroded part and reconnect.
If your surround speakers are on a stand the wires probably hang down and after some time, specially with thinner wires, they might get a bit loose in the connection. Simply reconnecting them will solve it.
Resetting the receiver will sometimes help as well, most of the times this is mentioned in the manual or on manufacturers site.
let me know if solved.
Posted on Aug 08, 2008
SOURCE:
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
Apr 19, 2010 | Kenwood VR-606 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Mar 16, 2009 | Kenwood VR-305
Surround sound
The unit has only 2 channels of output thus, cannot provide surround format. Depending on your sound needs, you will have to shop around for a good 5.1 or 7.1 surround unit
Oct 14, 2007 | Kenwood 104AR Receiver
Kenwood KA-994 Amplifiler no sound from rear speakers.
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
Oct 08, 2007 | Audio Players & Recorders
90 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
