JVC RX 809V home reciever
I can't find the manual and am having trouble setting the radio stations to the preset channels. Also need help with the character input for each station. i can progra up to 40 channels.
I need to set up surround speaker
Posted on Mar 18, 2011
    Scholar:
  • 144 Answers
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Posted on Aug 08, 2008
How do I get a copy of the manual for tretech clock radio TCR4964
Try Googling (TruTech)(TCR4964)(manual) without parentheses.
Jan 08, 2017 | TruTech TCR4964 Clock Radio
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Jan 06, 2017 | Yamaha Audio Players & Recorders
Kenwood VR-357 Audio Video Surround Receiver manuals
Try Googling (kenwood)(VR-357)(manual) without parens.
Jan 02, 2017 | Kenwood VR-357
I have a matsui MCH 750 mini hi-fi,i am having problems with the FM radio channels,sometimes or most of the time i get what seems like the channels are not tuned in properly or the aeriel is not good
If you're sure the FM signal strength at your area is good, the fault is with its AFT [Automatic Fine Tuning] system circuit inside the device. Contact any service technician to get it repaired. This is not a user repairable fault. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
I'm trying to locate a conversion plug, the subwoofer is a JVC powered sub . The connecter number is xv - thm 505. Next numbers are xv- thm 606 I need a female RCA to the sub 8 pin mini din W
not sure where you are based, but have you tried maplins electronics store? They tend to carry a large stock of lpugs and cables, plus they do seem to deal with audio equipment. Good luck.
Mar 20, 2013 | Audio Players & Recorders
I have a 1970's Panasonic Flip Clock Radio. (Model RC6530) The radio works just fine, but the flp clock stopped flipping. There is power going to the unit. I can also hear a low hum from the flip...
It looks like your problem might be an easy fix, at least. If the gear train between the motor and clock got stripped, you'd be in a bit more trouble. If the motor just isn't spinning, remove it from the side of the clock housing. There are 2 screws (or nuts) holding it in place. When you get it off, the cover for the motor will also be off. Apply some 3 in 1 oil, or perhaps just a tiny bit of penetrating oil, and give it a spin. From what I've read, it should do just fine. A lot of people use wd40, but I understand that can gum up over time.
This is a "at your own risk" type of repair, but as long as you unplug it before dismantling the radio, I think you'll be fine.
Feb 10, 2012 | Audio Players & Recorders
I have a Shontek radio controlled clock. It ran fine for a couple of years, then the battery died. I install a new "Durcell" battery and it went through the motions of setting itself but was a...
Your radio should have come with a receiver of some sort for the radio signals to set itself. I had this same issue with my clock when the battery in the receiver died ... try replacing this too. It took me forever to figure out what it was because I had forgotten that it had its own radio receiver ... then once I remembered it existed, I had to find it, but replacing the battery fixed the problem. Hope that helps :-)
May 26, 2011 | Audio Players & Recorders
Front two speakers not working at all
Hit the the speakers A/B/Off button on the receiver. If you plugged the front channels speaker wire next to the center channel on the back of the receiver make sure its showing B. If you plugged them in the banana plug part, make sure its showing A.
Apr 12, 2007 | Audio Players & Recorders
631 people viewed this question
 Grubhead
Grubhead
