Question about Dishwashers
When on/off button de-selected large flash from top of door. Main consumer unit tripped and fuse in plug found ruptured. Fuse replaced cb reset but dishwasher has no power. Fuse rechecked found to be good.
  • johnlewins Aug 08, 2008
    Fogot to mention this is a hotpoint aquarius df23 dishwasher
Dishwasher stripped down and found MAIN WIRING HARNESS chaffed agains door during opening and closing. New loom in region of £100 so repared old loom.
Posted on Aug 11, 2008
I have a washer kemore 600 series, it pumps water in but will not do anything else. Is there a reset button on the motor or pump?
Hello there and welcome to fixya
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? try to unplug for 15 min then reset the home breakeer than plug in the machine again and try Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video . at repair clinic.com Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or it will fill but will stop after that
Sep 12, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
I have a Miele T1413 dryer. It stopped working this morning. Light stuck in Anti-crease. Could not select another program or option. Please help.
If all of the buttons have frozen, is there a way to reset the washer? If not, how old is the washer, maybe after years of hard use it is time to buy a new one?
Apr 19, 2008 | Dryers
Washer does not start, no power, had power failure for 24 hrs after power came on washer will not come on, there is power in the outlet. is there an internal fuse or reset button, manual unavailable,...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 09, 2010 | Washing Machines
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Hotpoint WD72 - Plug Fuse Blows on Final Spin/Rinse
Hello thesquiffys
Welcome,
You said,
During final spin/rinse a vibrating/buzzing noise begins behind the from panel and which appears to be coming from just to the right of the soap drawer. After a few seconds, either the trip throws on the household consumer unit, or on one occasion, the fuse in the mains plug blew as well. Have noticed (don't know if connected) that soap drawer is often found containing water after machine is finished.
1.The soap dish needs to be cleaned out, holes clogged. The instructions for this
process is in the user guide and I'll paste the site below for you in case you do not have it available to you.
2.The noise sounds like a short or electrical problem starting.
For this you will need a hands on diagnoses.
TRY doing the soap drawer first to be sure that it is not the culprit!
The book can be found here and the drawer info on page 12:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWD72.pdf
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank You
Sep 28, 2008 | Hotpoint Ultima WD72 Front Load...
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
Feb 27, 2008 | Washing Machines
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
GFI outlet fuse trips even when nothing is plugged in
hi there, there is a shorted electronic parts at your power supply, fuse allways blows means a shorted diode, regulator and a transistor. it should be replace, do some testing and replace the defective parts. ty
Jan 10, 2008 | Computers & Internet
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
