Question about Sharp AR-5316 Advanced Digital Imager Copier
Delet code I have AR-5316 digital Sharp copier machine and appearing E-7, sub code 10. I want to delete this code. let me know hou to delete code.
  • jkparekh2003 Aug 09, 2008
    It's helpfull and good for guide line but how to delete the E-7, sub code 10, please I am seeking solutation. what is the procrdure to delete this code?
    yes I hear some chi..chi..chi..noises when the machine is initializing?
Yes I hear grinding noises when the machine is initializing.
is ther require any lubrication? i brought a silicon grease for gearing system.
Posted on Sep 03, 2008
  • 62 Answers
Their is a rom update that a sharp tech will have to install on your machine to fix this problem
Posted on Aug 14, 2008
  • Sharp Master
  • 2,794 Answers
It's an calibration error caused in the optics section. Make sure there is nothing on the scanner glass but the cover itself. Turn the power off, wait 30 seconds and turn the power back on again.
Do you hear any grinding noises when the machine is initializing?
Posted on Aug 08, 2008
  • Tim Babcock
    Tim Babcock Aug 09, 2008
    The code does have a service code to delte itself. Check to make sure that the scanner glass lock isn't enabled. It is located underneath the scanner on the left side.
    Keep an eye on the cable as well underneath the scanner and make sure that it isn't jamming the copier as well. Let me know if it is.
  • Tim Babcock
    If the scanner is jamming underneath the cable, you can take some scotch tape and secure it down flat onto the surface. I've seen that happen before.
Code erreur u 2 sharp ar 5316
memory error, pls press the copy key to see what the sub code is...if 04 appears, eeprom problem failure....try to cancel using simulation 16.
Jul 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
I need a driver for sharp ar 5316 and windows 7 profesional Thank you
http://support.sharp.net.au/drivers/, go to this link click software and driveres, then click photo copieres you will get all driveres for allthe machines then scroll down to find ar-5316 click then click on windwos 7 then download pcl6 driver, rate this and vote for this
May 17, 2011 | Sharp AR-5316 Advanced Digital Imager...
Solutions for Sharp copier 5516 error code f 2
If you change the toner nearly it refer to toner cartridge otherwise ; press "print" key to see the sub code. and if I know the sub code I can hep you more .
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Advice on how to re-set sharp ar 5316 copier, procedure.
Hallow, its my assumption that you know the command numbers and their sub-codes and error codes when you ask of procedure. Here is the procedure:
  1. Press #, Interrupt, 0, Interrupt , keys in that order.
  2. The copier display must go off, if not repeat and increase pressing speed.
  3. Enter the desired number and press copy key.
  4. If it has sub-code, then enter it and press copy key.
This is the procedure.
Nov 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
5316 SCANNER DRIVER
the sharp 5316 does not work as a scanner
sorry for that
Feb 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
E-7 sub code 10
Check connection of the ccd cable to the ccd and the pcu board, if all good the you have problems. try reseting the m/c first
Aug 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
112 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
