Iv added extra speakers, 2 a small hifi but wen i turn it up the sound cuts out !!!
    Scholar:
  • 144 Answers
It is not possible to just add extra speakers. Most likely the total OHM of the speakers is just too much for your amplifier making it go into protection mode. Just disconnect the additional speakers.
Posted on Aug 08, 2008
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Hi , is it possible to add an extra 2 speakers to my hifi even though there are only enough terminals to hold the 2 that was with it ???? also the run of cable nedded for the added 2 speakers will be...
Yes you can add two additional speakers, by adding a splitter off each terminal, which will take each terminal hole to two. However there is a couple problems you might discover. Power output will weaken because each channel is designed for so much amp output. So, by adding two additional speakers off those channels demands more power. Now, if your not going to crank them high and have a block party you will be ok. You can get the splitter that goes in to each port and splits and places like Guitar center, maybe radio shack, best buy, and even check walmart.They make also little devices that are a little unit that actually is separate, that hook up like this. Two small coax lines about 6 inches long come out your receiver and plug into this little splitter that has four ports, then you can run all four of your lines to the four speakers, and this device has panning and some other little features to make one speaker louder than the other like a fader. I hope this helps. Again Guitar center is best to check first.
THANK YOU, MIKE
Sep 10, 2011 | Audio Players & Recorders
How to i connect my bose companion 2speakers to my computer and get sound
hi, first Identify what computer you have. Is It A Mac or PC?
If it is PC
There should be 2 small 3.5mm coloured sockets on the back,front (or both ) of the main box (tower/desktop unit). You should find that they are coloured Green and Red. Green is for sound output (Headphones/speakers or hifi) and the Red is for sound input or Recording. Used for things like microphones. Some will accept line sources such as mixers and Ipods pr cassette players, but please check your sound manager, mixer settings in your opperating system to make your you have an adjustable input setting for Mic and Line input attenuation as not all do and you may end up with a distorted mess. You may also find there is a small diagram of headphones or a microphone to indicate sound "in" and "out" ports.
If you have a mac
Appart fom me being envious :-) there are two sockets. On laptop types, on the side or on the tower types on the front,back or both. They have a diagram of a microphone and headphones. Hadphones is for audio output to headphones, speakers, hifi, dj mixer. The Microphone is a sound input. Please read above for microphone port usage. Hopefully this answers your question. Please also bear in mind that if you have no sound once plugged in, you may need to adjust the audio properties in the system in the system and/or program you may be using
Dec 29, 2010 | Bose Companion 2 Series II Multimedia...
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Can i connect extra speakers to my hifi unit if
to be honest i dont think it really matterys what impdance the speakers are just connect the new speakers in parralel with the old ones
(positive to positive and negative to negative)
Jan 14, 2010 | Audio Players & Recorders
I added 2 more speakers and a subwolfer to my gateway pc,no sound
thats because there are no extra ic amp chips to run the speakers you can only put extra speakers on if the unit if it is designed to have them added
Oct 26, 2009 | Gateway DX4300-03 Desktop PC
B speaker setup problem
Why don't you set it Zone 2 then you could listen to the radio outside and still watch tv inside. You can turn it on and off just like a and b speakers.
Jul 07, 2009 | Yamaha RX-V663 Receiver
Car dies
If it has a regular carburator, replace the acceleration pump. It's a small diaphram on the side, near the fuel inlet.
Nov 30, 2008 | 1991 Chevrolet Cavalier
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
44 people viewed this question
 Grubhead
Grubhead
