Question about Canon S520 InkJet Photo Printer
Flashing green light prevents printing.
Was getting 7 yellow blinks, 1 green glink over & over. Lifted grey print head lever which stopped yellow blink, but now have continual green blinking light. Can't print with flashing green light, & an error message comes up when I try to print. Can you please help with solution to this problem?
  • Anonymous Mar 21, 2014
    able to fax and copy but not print from computer. continuous flashing green light
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Posted on Sep 19, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Canon S520 printer stopped printing has 7 orange lights before the green light on printer has an error code
Hi ...
light flashing 7 times means that there is an issue with printer head. Try and perform the below steps to reset the printer head whcih might resolve the problem. If this doen not, I would suggest you get your printer checked by a technician.
Reseat the print head
  1. Confirm that the printer is powered on.
  2. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
  3. Hold and slowly move the print head lock lever up and down several times.
  4. Lower the print head lock lever to secure the print head.
    Note: Holding the print head may cause it to not be seated properly. Perform this step using only the print head lock lever.
  5. Close the front cover.
Don't forget to vote if this helps ... Cheers :)
Aug 05, 2009 | Canon Office Equipment & Supplies
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
3. Release RESUME
0 presses - green light - Test Print (exit service for i960)
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Office Equipment & Supplies
Canon i550 problem
The yellow blinking light is not reported in the code errors, take a look to service manual http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
(hard to find but I did it ! )
I had the same problem and I solve it sending the clean head command from the settings of the printer driver (win XP)
I also reset the printer as it is explained in the service manual.
Nov 02, 2007 | Canon BubbleJet i550 InkJet Printer
Canon S520 InkJet Photo Printer Logo
690 people viewed this question
old marine
old marine
Corne Viljoen
