Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
How can I program my MTS 2000
I have a couple mts2000 radios that i want to program with my work radios these are also the mts2ooo models and want them to be compatible with my existing work radios. Is this possible? How do I now? Can I just use a clonning cable or do I need the RSS and programming cable?
  • Motorola Master
  • 1,654 Answers
Most Motorola shops, including ours, will program the radios using Motorola proprietory RSS for a small fee. (Ours start at $25 with $5 for each additional unit cloned via the RSS.)
Cloning via the RSS is only possible if the units are all the same exact model number.
Posted on Aug 11, 2008
I need software for motorola mts 2000 flashport
You would need a programming cable as well. This is more likely than not beyond your current level of skill. This software is licensed by Moto, complex and not easy to get over the web. I suggest that first you sit down and make an outline of exactly what frequencies you want to transmit on if you are licensed and what to scan etc and go to a radio shop. It will be worth the money.
Aug 31, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
How do i program my motorola mts 2000 flashport scanner
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Need unlock code
It is possible the radio was "password" protected by the dealer who originally programmed the radio. If this is the case, you will need to find the original dealer who sold the radio to find out the password. OR you will need to send the radio to the Motorola factory repair depot to have them clear the memory of the radio. (It is not something the local Motorola dealer can do.) You can contact Motorola at 800-227-6772 for more info.
Apr 08, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola mts 2000
MTS2000 software will operate on Win98 and possibly XP, depending on the revision number you have. Yes, you can clone if the model number is the same. It will clone the entire codeplug of the radio. (Note: you will not have 2 same serial numbers. These are unique to the individual radio.)
Aug 16, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
MTS 2000
The radio can only be programmed or adjusted by the use of a computer and the proper software. What exactly is it doing or not doing? Do you keep it on the charger all the time?
Dec 20, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
INEED HELP
A Motorola MTS2000 is a government issue 2-way radio, hence user manuals are restricted. You can try ordering them with Motorola (800‑422‑4210). I was made to understand that manual part number starts with “68” and ends with a “-O”. Version would depend whether you have the I, II, II versions in either VHF, UHF, 800 or 900 MHz.
Since this is your 2nd posting of this model and based on your profile however, I would assume that your requirement is technical in nature (field programming, repair, maintenance, etc), perhaps a Service Manual would fit you better.  It is available   here in pdf. A Spec Sheet is  here  likewise in pdf.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
221 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
