Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo booting problem
I've a lenovo 300N100 HCQ model. after pressing the power button it is taking more than 10 minutes to start the booting process. once it starts it is booting normally with out any error. after pressing even the screen is not glowing only power LED is glowing.
any one help plz
  • brama Aug 08, 2008
    thank u, 2day i'll try the same..
    Scholar:
  • 176 Answers
So u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Posted on Aug 08, 2008
My Lenovo G570 Is not booting The screen blinks on and off Any suggestions
Hi
You could try this - press the power button down for about 10 secs, to make sure that the computer is completely powered down. Then press it again to start up and as soon as the logo appears start pressing the F2 key. This should take you into BIOS. If this screen is steady, then the problem would appear to be in the set up of the machine. If it blinks on and off at this stage I would suspect a faulty connection to the screen, or a hardware malfunction. If the latter it will need to be diagnosed by a professional and repaired, at which stage the cost may be better put towards a new machine and taking the drive out of this one for data retrieval.
A manual for your machine in pdf format can be found here, and saved if need be to your hard drive for future reference.
http://download.lenovo.com/consumer/mobiles_pub/lenovo_g470_g475_g570_g575_ug_v2.0_english.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Lenovo Computers & Internet
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
I have a lenovo y 430 laptop and i want to restore it to factory setting. So I start with the laptop switched off. I click on the OKR button. My laptop just boots up as normal. Once it is on, I press the...
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer.
If this fails, then call them.
http://www.lenovo.com/planetwide/select/selector.html
May 13, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Lenovo ideapad y530 not booting. The light at the top left corner is not switching off inspite pressing. I want solution from lenovo company itself.
Welcome to Fixya
Looks like the board hang up on you. Take out the battery and unplug the power adapter from the computer. Press and hold the power button for 10 secs then put everything back in. Turn on the computer. Computer should boot up now.
Please reply to this email if you have further questions.
Thank you for using Fixya!
Mar 29, 2011 | Lenovo IdeaPad Y530 PC Notebook
I ve problem when i try to shut down my lenovo G550 2958 laptop.Pls help...
Hi knabeela86,
What is the problem that you are encountering when shutting down the computer?
Try also to perform power drain it might help.
How to perform power drain:
1. Turn off the computer completely.
2. Take out the battery from the system and remove the AC adapter.
3. Press and hold down the power button for 10 - 15 seconds.
4. Put back in the battery and AC adapter then try to power on the computer.
Hope it helps,
Thank you for using FixYa.
Dec 17, 2010 | Lenovo G550 (2958ACU) PC Notebook
I have lenovo 3000N seriesr laptop of HCQ model. when i am switching the laptop only white screen with lenovo written is comming,what may be the problem
Turn on your computer. Watch the display carefully while your PC starts. While the initial screen ( LENOVO ) is displayed, press the Lenovo Care button. The Rescue and Recovery workspace opens.
Click Restore your system > Restore my hard drive to the original factory state > follow the instructions on the screen.
If Rescue and Recovery did not launch, the motherboard may need replacing.
May 19, 2010 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 c200 wont power on
try to perform battery drain. you need to take out the battery and unplugged the power adapter. press and hold the power button and count 1-10. release the power buttong after 10. do it for 3 times. after that, plug in the adapter and power adapter and observe.
Mar 25, 2010 | Lenovo 3000 C200 Notebook
Yesterday My IBM T23 laptop froze..I hit the power button to unfreeze it. It powered down and re started but now it takes about 10 minutes on the Windows XP screen and a good 20 minutes to get to the...
Try to boot up in safe mode this is done by pressing F8 during boot up select safe mode with networking after it has completed and run for a little while reboot up in regular mode.
Hope this helps
B52Computers
Dec 07, 2009 | IBM ThinkPad T23 2647 Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
219 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
