SOURCE: i forget my security code on my nokia 1661, how
i forget my security code on my nokia 1661, how can i reset it to default without using it?
SOURCE: lost security code for my nokia 1661 prepaid
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones. if this code dont work then you will need to do a hard reset. a hard reset will delete all of your files but your phone will be open and you can make a new password. always make a copy of your password and store it in your wallet or at home some where . codes for reset >
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone
SOURCE: how to open security code in my nokia 1661
dear it is very easy to open the security code if you have not changed the code ...by default code is 12345.if this code have been changed then only one solution then renew the software.ok.
SOURCE: security code
If you cant get the phone to come on then get the firmware re-installed. This is the problem with codes. There is no magic key that can open all locks.
