you need to reinstal the firmware on your machine, And for the E007
check if the new film is rotating in the same speed as the presure
roller, check if you mounted the film sensor corectly, and if the sensor
is reading the corect end of the film ( it schould be the one whit a
white square on it).
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says: E007 0000 Fixing film sensor failure The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Hi
I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error
E007 .. and some times when i turn on the copier it shows this error
. How can I Fix this error ... please help me .
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
