Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Wont record or playback tapes
Started to play back tape and it had lines across it and now it wont play any tape or record. It runs the tape but just blue screen and no time codes shows. What happened?
  • 1 more comment
  • videonut1 Aug 08, 2008
    I have not cleaned the heads
  • Anonymous Nov 28, 2008
    my tape is stuck in pd170. the tape does not eject or play back? what is the solution for it?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you cleaned the tape heads recently?
  • Sony Master
  • 2,794 Answers
There you go. Thats a good way to get the problem solved.
Posted on Aug 08, 2008
Lines across tape while playing
It sounds like either the recording head of your camcorder was dirty when you made the recording, in which case you will need to clean the record head and re-record, or the playback head is dirty.
Either way, you should be able to solve the problem by using an 8mm head cleaner tape which you can buy from the same place you get your camcorder tapes.
Hope this helps,
Chris
Mar 05, 2011 | Sony (41989) Hi-8 Tape
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
267 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
