Question about Oster 76076-040 Hair Trimmer
How do i change the blades
I took apart my oster pro to get hair out and now i can't get the blades back in, what do i do
    Problem Solver:
  • 13 Answers
Have you tried having the blade running when you slide it back in?
Posted on Jan 09, 2009
SOURCE:
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I took my oster trimmers apart now i dont know how to put them back together can u help me
Unfortunately, Oster does not publish any real maintenance manuals. Basically, if you only took apart the cutting blades and the oscillator, it's not too hard. If you tried to take apart the electric motor, that's a whole different story. If it's just the blade assembly, carefully align the blade assembly with the groove pointing into the trimmer handle and hold the blades together so that they are parallel, not crooked and reinsert the screws. You will see how the blades align, based on the wear marks on the bottom blade guide. If you took apart the oscillating arm, then line up the cam pin with the round hole in the arm, then replace the screws that attach the top blade to the oscillating arm. You may have to push in the tension arm so that you can align the screws with the threaded holes on the handle first. Final step is to screw the bottom blade guide back onto the handle, again align the guide with the blades so that they are parallel and not crooked. The best way to do this is to start threading the screws, then before tightening them all the way, align the blades first. If none of this works, go to this website: http://www.osterstyle.com/CustomerService.aspx and locate an authorized Oster dealer/support center near you. You'll probably have to mail the clippers in to one of the sites.
JB
Feb 25, 2011 | Oster T-Finisher 76059-010 / 76059-030...
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Jul 14, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-040 Hair Trimmer Logo
394 people viewed this question
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Falling star
Ross Keen
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
