Question about HP OfficeJet 6210 All-In-One InkJet Printer
6210 Not Print Magenta
Tried prime clean and etc. It just refuses to print Magenta even with a brand new HP catridge.
  • 40 Answers
Try to clean BOTH copper contacts of the printer and cartridge
- and try to run again the alignment page.....
- if the issue still persist it is a hardware issue...
Posted on Aug 31, 2008
Print blurring
you have to clean the lsu. laser unit. you will see there is a lot of dust on the bottom mirror inside. it is a big job. advice that you must be tecnical.
Feb 29, 2012 | HP Color LaserJet 2600n Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
HP Officejet 6210 refuses to print in color although new catridge installed.
Fire it if it refuses! You have to do a setup and alinement page go to this web page for help they also have a self test for it but you may have burned out the color print head, that happens when the ink gets low and burns out the printer head, they warrenty them for one year after purchace so be sure to register first befor trobleshooting that way it won't cost you nothing. Hope this helps.. http://www.appliancepartspros.com/modelsearch_model.aspx?part_id=2071523&model_id=301086
Nov 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer won't print yellow and blue.
Please Buy original hp printing catridge from an authirised dealer of hp.
Oct 26, 2009 | HP LaserJet 1200n Printer
D7260 not printing some colors
1.Try placing sheet of Magenta print on copy board, and run many copies .  Run head clean after about each 50 sheets.
Apr 24, 2009 | HP Photosmart D7260 Printer
Shows catridge empty
If you want to use this non-
HP print cartridge, press
(Cancel Job) to continue printing.
Dec 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Cartridge
whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP Deskjet 932C printer will only print in magenta
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet.
Jul 03, 2008 | HP DeskJet 932c InkJet Printer
Yellow ink not coming thru
The ink jet is block this happens when you don't you your printer for a long time or you use the genetic cartridge. What you could do is disassemble the printer head and use hot water to clean it out. Good luck
Apr 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
