Jc4lifes3as
I have provided instructions on how you can program your remote to your TV.
Without knowing the brand TV you have, I have provided a link with the codes you
can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the
Television On.
2. Press and hold the TV Power button for three seconds until the
LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with
the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off,
change the volume and mute the television.
Power Scan:
Remote: Basic Remote
(Television Only)
1. Turn the Television On.
button for three seconds until the LED flashes.
3. Press and release the TV
Power button.
4. Press and release the Up or Down Arrow on the remote until the
television turns off.
5. After the television turns off, press and release the
OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote
is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your
receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray
Calo
DISH Network"
