Question about Acer AL1914 19" LCD Monitor
Pixels? I have had this monitor for probably over 3 years maybe 4 im am not sure. I now constantly get a blurry screen filled with red pixels making it very hard to see what is on the monitor. Also sometimes the screen gets wavey and everything is distorted.
    Scholar:
  • 144 Answers
Seems your screen is about to die unfortunately.
To verify this see if you can connect your PC to another LCD screen, if the problem persist it is not your screen but your PC.
In case it is your PC, just clean it out (blow compressed air to remove all dust from your casing) and reinstall driver displays.
Otherwise i'm afraid a new (or used) monitor will be mandatory...
Posted on Aug 08, 2008
Blurry pixel display of AOC monitors.
Hi, In my experience, it looks that the screen pixels are damaged in some areas. It could be due to mishandling, may be fallen or it could be a manufacturing defect. If the device is new, ask for the replacement as it may enlarge due to heat. Rest is your luck :)
Sep 28, 2017 | AOC Monitor
Milk white screen.
HELLO!!!
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
I have an HP L2208w monitor which has been ok for the last two years. Suddenly, it started to display patches of different colours. Also vertical and horizontal colours appear across some pf these patches....
hi steven_katas
Im thinking that this maybe a LCD panel problem (dead pixels) already. some LCD panels last for 2-3 years depending on usage. even if you haven't dropped it or anything the LCD panel's pixels ten to give way slowly or die down since these pixels are like bulbs. here's what you can do. Try connecting a different cable from your monitor to your computer if the issue is still the same, try connecting a different computer or maybe a laptop to your monitor just to eliminate the probability that it can be a cable or a video card problem.
If you have already connected a new computer say a laptop and it is still the same it might already be a hardware problem with your monitor and might need you to bring it to the service center for repair.
Hope this helps please let me know
janc30
Feb 13, 2011 | HP L2208W Monitor
I HAVE RED DOTS ALL OVER ANY BLACK COLOR OF THE PICTURE
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
Nov 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
Gateway monitor pixels discolored on monitor
This happens when you keep a device close to monitor which uses wireless technology or signal(Cell phone, wireless router or modem). Also try to make distance between speakers and monitor, as speakers contains magnets and that causes such issues.
Nov 18, 2009 | Gateway Profile 5.5 Desktop PC w/17"...
Everything is blury have to set screen resolution to 800by600 pixels to try too make any thing out.
Connect the monitor to a laptop -- is it still blurry?
If so, then the monitor is the problem.
If not, then your computer (the video-card?) is the problem.
Oct 31, 2009 | HP Vs17 17" LCD Flat Panel Monitor
RGB Pixels
sounds like the graffix card maybe over heating you will probably get e74 error and have to send it in same thing just happened to me.
Jun 08, 2009 | Microsoft Xbox 360 Console
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Acer AL1914 19" LCD Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
