Question about Dell Dimension 3000 PC Desktop
Dell desk top
I was recently fooling around behind my dell desk top pc and an eletrical cord was causing my power strip to surge for some reason, the next thing i know my pc shuts off and when i go to turn it back on, it will show me the dell screen but then a gods-aweful beeping sound happens and it stays like that till i turn my pc off. what i need to know is did i fry my mother board? i even tried the Ctrl+F11 which usually speaking would bring me to a system reboot screen, which would completely wipe my hard drive and everything else clean.... i got absolutely zero response.
  • confusedbrit
    confusedbrit May 11, 2010
    What is the pattern of the beeping noise? Different beep codes tell of different faults you see.
    Problem Solver:
  • 5 Answers
I really can't help you there the best that I can do is give you the number to a guy in South Carolina who is like a major computer nerd and can possibly help you out. His name and number is Dwight Welsh and
(910) 494-7467. I know that he would more then likely be able to tell you what is wrong with it because he's fryed his mother bord before no thanks to my lil sister by spilling hot coffee onto it! so if anybody would know he would!
Posted on Sep 14, 2008
WILL NOT TURN ON!
Is this a new problem and this ran fine until now? If so, you want to make sure you have power going to the computer, power at power strip or surge protector, cables all plugged in correctly and tight. If all that checks out then the most likely cause is the power supply has failed. If you have had power surges or electrical storms recently this could be the cause. If not, your capacitors in the power supply could just be at the end of their life and died.
Oct 09, 2014 | Dell Inspiron 531s Desktop Computer
I press the power button but the machine does nothing. It's pluged in and the lcd lights up
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
    • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
      1. Unplug the power supply from the rear of the product.
      2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
      3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
      4. Wait 15 seconds.
      5. Reconnect the power cord to the power module.
      6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
      7. Check to see if the power module has an LED.
        • If the power module does not have an LED, continue to the next step.
        • If the power module has an LED, check to see if the LED lights up.
          • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
          • If the LED lights up, continue to the next step.
      Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
      1. Reconnect the power supply to the rear of the product.
      2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
      • If these steps resolved the issue , there is no need to continue troubleshooting.
      • If the issue persists , see the next step.
      Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
      • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
      • If the product does not turn on with the alternate power cord, continue to the next step.
      Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
Printer will not come on when pushing the power button
  4. Wait 15 seconds.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 17, 2010 | HP PSC 1315 All-In-One InkJet Printer
I have a hp officejet 7410 it keeps losing connection with wireless router, I need to do a hard reset to factory out of box condition, starting from scratch seems the only way to get it back on line,...
May be you can try to perform partial reset by :
  1. Disconnect the power cord from the back of the product, and then wait for 20 seconds.
  2. Press and hold # and 3 on the product control panel while connecting the power cord to the back of the product.
  3. Release the buttons when the product turns on. The reset is complete..
Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  4. Wait 15 seconds.
  2. Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
Dec 02, 2010 | Computers & Internet
My dell dimension desktop does not come on. all i am getting is the monitor in power save mode, and the computer fan is running.This has occurred after my electricity supply was lost and came back on. I...
you can try checking if there's a HDD led activity but as per what you have said, this is either caused by a power supply or mainboard failure. Sometimes, surge strips cannot guarantee that it will protect your computer from unstable current caused by on and off of the electricity.
Aug 07, 2010 | Dell Dimension 9200 PC Desktop
Printer will not become ready.
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure the other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strip as it may cause power loss. If you check around the silver contacts on the power adapter, there should be a green LED light on. If not, that's the cause of the problem. If it's on, plug it back in the printer in the right position and properly secure it. If it won't power on automatically, press the power button. If problem persists, the printer itself is the problem. If these are the cases, I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 02, 2010 | Lexmark X4650 InkJet Printer
3210 printer won't respond!!! I cannot print out anything on this printer, but it was working one month ago!?!?!
Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  4. Wait 15 seconds.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
Apr 07, 2010 | HP Photosmart 3210 Printer
Model ATF6000751. Replaced speed control board a month ago when final spin failed. Worked fine until yesterday. Could something else be causing the board to go bad?
Power Surges. In my area we suspect that 70 to 80% of the repairs here are caused by power surges. They happen all the time, andyou do not have to lose power to have one. They can happen when you have lightning, windstorms or beutiful sunny days. You have to have a 2000 joule surge protector or higher on your washer, refer, microwave oven, and gas stove or dryer if you have them. For your washer , gas dryer, and refer you have to have a rectangular box wall mount surge protector. You cannot have a power strip surge protector on a cord as moisture can get into it and cause electrical fires. I have seen three major fires caused by power strips behind washers. Lowes and Best Buy sell wall mounted box surge protectors with a 2150 joule rating that have 3 plugs on each side that rotate from front to the side so that you can plug your refrigerator into the side and not have the refer sit out from the wall any more. Good Luck, Appliance Specialists.
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
My computer is not starting after a power failure.
you probably damaged the power supply. open up the tower and check if a light is on the motherboard.
Oct 22, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
