Question about Samsung SF-560 Plain Paper Laser Fax
Bad copy to sender cant read
Sent faxes i am told are not readable very faint tried cleaning scanner bar but no joy please help
Ok thanks faulty phone line
Posted on Aug 08, 2008
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Although I read the manual, I cannot figure out where or how to clean the scanner which I assume is where my problem is. I only get vertical lines when copying. Faxing is fine. Can you help?
Faxing is fine , when sending or receiving ?
any way I do not think you need to clean the scanner . if you can send a fax and other party can get the fax your scanner is ok . If not you need to replace the scanners light which is a glass looking bar close to your document feeder
Oct 25, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Lines down middle of copy and fax
You probably have a bad SCANNER ASSEMBLY.
Try opening up the document feeder and cleaning the scanner glass
Jan 21, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Faxing is clean, streaks occur when copying
Open the document feeder cover. The scanner glass is dirty or you have a bad scanner block.
Dec 05, 2008 | Brother IntelliFAX 4100 Laser Fax
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Printing report or making copy
Lift up the operation panel and look for debris on the small glass strip.
If that's clean, you might have a defective thermal head.
Jul 17, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Lexmark X6170
Received fax is unreadable or blurry
Please go through the checklist below to see if the suggested action(s) can resolve the issue.
* Make sure the copy function is working well.
* Print a Clean nozzle page from the Maintenance menu. If the printout has unexpected white or color horizontal streaks or missing portions, print the Clean nozzle page again. If you are still experiencing streaks or mission portions, you may need to replace your cartridge(s).
* The cartridges may need to be aligned.
* You may need to ask the sender to increase their fax quality.
Sent fax is unreadable or blurry.
1. If the receiving party indicates that the fax output is unreadable or blurry, you may want to try increasing the fax quality.
2. Check the scanner glass for excess amounts of smudges and/or fingerprints. If the scanner glass needs cleaning, moisten a clean, lint-free cloth and gently wipe the scanner glass. Make sure the scanner glass is dry before scanning the next document.
Feb 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Samsung SF-560 Plain Paper Laser Fax Logo
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
