Question about Microsoft Windows 98 for PC
Window is not running properly
The window98 in an old laptop show problems
when we on it ,it show the window then command prompt is started like this c:/>
and if we gave any command it says bad command
it doesn't come out of it
please tell me what is the problem & how i can solve it
  • 446 Answers
Type help on the command prompt and enter, and it will show the list of all commands.
Posted on Aug 08, 2008
When I turn on the laptop, the asus screen comes up and it seems to be booting but after a long while shows an error and restsrts never actually booting up
While it starts to boot up, press the ESC key, or appropriate key that allows you to enter into setup. From the setup area, look for an option to boot into safe mode or into a Command Prompt. Once in safe mode, if it works, press start, and go to run and enter CMD. In this window type in bootrec /fixmbr and press enter. Next type in bootrec /fixboot and press enter. Restart your computer normally.
If you can start in the command prompt, enter in the same commands.
Also if you have a windows recovery or windows installation disk you can access the command prompt as well as fix any issues that are cauing your machine to not boot.
Here is a step by step guide on how to solve such problems.
How to Manually Repair Windows 7 Boot Loader Problems
Apr 23, 2015 | ASUS Computers & Internet
Tip
Disable/Enable Hibernation in Windows
To make hibernation unavailable, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate off</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol> To make hibernation available, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate on</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol>
on Mar 26, 2011 | Computers & Internet
My laptop is Acer and it is showing like "we apologize for the inconvinence, but windows is not starts successfully" and showing some options like safe mode, safe mode with networking, safe mode with...
Here's the step by step on how I fixed this particular problem:
First, boot the computer into safe mode with command prompt. To do this, start the computer, and immediately begin pressing the F8 key at one second intervals. You may have to press several times until the boot menu comes up.
Use your arrow keys to choose Safe Mode with Command Prompt and press enter.
The computer will begin booting. Lots of weird looking white text will scroll by and then the computer will ask you to login or give you a box saying safe mode is running, etc.
Click Ok to finish loading. A black command window will appear with a c: prompt.
At that c: prompt, type chkdsk c:/r and press enter.
Check disk will start to run but then it will say:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y for yes, and press enter. Then reboot the computer into normal mode. Chkdsk will start when Windows begins loading again. Let all 5 phases run and don't use or turn off the computer. (The chkdsk process may take an hour or more to finish.)
Chkdsk finds any corrupted files that are causing the problem and fixes them. Read the results of each phase as it finishes. During the final phase, it will notify you if it finds any corrupted files.
When the Check Disk is done, it will finish loading Windows.
May 05, 2014 | Computers & Internet
I cant get laptop to start up!
LOL, when will consumers ever learn to stop being so quick to go out and buy the latest and supposedly greatest operating systems? Windows 7 is so much like Vista with the problems of Startup Repair not working and losing devices, etc.
You reinstalled windows and it still does not work?
Ok, after Startup Repair tells you it cannot repair the problem. Click the option that takes you to the Recovery Menu to see other options. Down at the bottom select the Command Prompt.
When the command prompt window opens (black screen with white writing) they the command:
sfc /scannow then press Enter
When Sfc (System File Checker) finishes run the Check Disk Utility ( I ran one this week on someones computer that was doing the same thing and Check Disk ran for 3 hours, but it fixed the problem).
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 20, 2012 | Dell Latitude D600 Notebook
My laptop keeps showing a microsoft windows that states CEEment and EsAdvRemIntegrator has stopped working.
You will need to open a command prompt in administrator mode. You can do that by right clicking the Command Prompt in the list
Start | All Programs | Accessories
Right click on "Command Prompt "then to "Run as Administrator".
Once you have an administrator command prompt open, type in the following:
sfc /scannow (space between "c" and "/") hit <enter>
Dec 17, 2009 | HP Pavilion dv9000z Notebook
No updates just error 646
Hi
This problem usually occurs with vista operating system.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%System32Catroot2 Catroot2.old
ren %systemroot%SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043” and install it.
Visit the following link to download the update: http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Hope this solves your problem
Dec 17, 2009 | Microsoft Computers & Internet
My computer will not install updates. it says it is installing them after it shuts down but they never install.
net stop wuauserv
net stop bits
net stop cryptsvc
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
net start wuauserv
net start bits
net start cryptsvc
Regards,
Om
Oct 11, 2009 | Microsoft Windows XP Professional
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
net stop wuauserv
net stop bits
net stop cryptsvc
net start wuauserv
net start bits
net start cryptsvc
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Upgrading Computer
All you have to do is re-boot from the xp disk.When promted,press any key to boot from the disk.The installation program will then start.Just follow the prompts from there!
Feb 21, 2008 | Computers & Internet
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Microsoft Windows 98 for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
