Question about Gateway FPD2275W LCD Monitor
Veiwsonic VA2026w. Yellow tint down R/h of display.
I purchased the above monitor six months ago. An opaque 2" yellow vertical line began flashing intermittently down the right hand side of the display.
This has now become a permanent addition to enhance my viewing pleasure (not).
I have checked graphic card, re- installed monitor and display drivers, removed any magnetic fields around monitor and even resorted to full virus/malware scans.
With no positive results from this little adventure i have re-installed my O/S and patted my head and rubbed my belly!!
Any Takers???
  • DuxNutz Aug 08, 2008
    Yea thanks..ezQ.. I am running XP pro sp2. I checked for EHTRAY.EXE, but it does not appear in processes, so nothing doing there. Strange alright...and very frustrating. I gave starting in safe mode a shot but not the desired affect. Still interested???
  • DuxNutz Aug 16, 2008
    Yep Given up the ghost I'm afraid.. On contacting Veiwsonic was told this problem was fairly commom. It's warrenty repair or replace for this one..thanks for all you help. I will be putting the word out about this site. AAA
    Scholar:
  • 144 Answers
Which OS are you running?
Try this, after staring your PC press CNTRL-ALT-Delete and go to the processe TAB. Check if you see EHTRAY.EXE running.If so kill it and see if the yellow line disappears. ehtray.exe is part Mediaplayer and runs on startup, sometimes causing strange things.
You can remove it from the registry safely but if youé not familiar with the registry don't do it because 1 error might mess up your PC.
Posted on Aug 08, 2008
  • easyq
    easyq Aug 09, 2008
    Check the link in my answer, there are some other files known to cause strange behavior mentioned there.
  • easyq
    easyq Aug 12, 2008
    One other option, turn the brightness of your monitor all the way down by using the adjusting buttons on the monitor itself, if the yellow line is still there, i'm afraid your monitor has given up on you. If the line disappears, it's most likely a software issue and it should be solvable.
Lines on screen
The screen has a connection for each line on the display and the soldier on some of these connections has gone intermittent. When the unit becomes warm enough, the soldier expands and the connections become more consistent.
If you're skilled, this can be repaired. If not, either replace the unit or take it to a reputable technician.
Nov 01, 2017 | Jensen VM9424 Car Video Player
Pink and blue vertical lines through
It could just need the print heads cleaning or aligning
If you are not sure contact the shop you purchased your printer from it is under warrenty for 12 months
Apr 03, 2010 | Computers & Internet
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
HP Pavillion zd8000 LCD problems
I had the same happen to me.. it started with one white vertical line.. then got the whole rainbow (red, green, blue).. Solution: Try connecting an external monitor.. if there is no problems, then it's not the video card or chipset.. it's going to be the lcd.. you can get it on ebay for about $200.. hope this helps..
Jose
Jul 16, 2008 | Computers & Internet
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
My Sony SDM N80 screen has turned yellow!
Well, I have 2 of these monitors and one began acting in a similar fashion right before the cable went bad. I acquired a replacement from another person with a broken monitor but I believe this site sells them too (but they aren't cheap).
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=SDMN80
Jun 18, 2008 | Sony SDM N80 (Gray) 18.1" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
