Question about Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 turns off/on and does not respond to remote
Bought this TV in 2006 from Circuit City . TV will turn off power light blinks for about 30 seconds then it comes back on. At first this happened maybe once a night now it happens about 6 times in 1 hour. Circuit City has been out 3 times and cannot resolve the problem. They have replaced the lamp twice and still not fixed. Since they have not seen the problem there is no problem. I went on line and found that we needed the software upgrade. Sony came out did the upgrade and problem still exist.
Any one have any ideas or advice???
  • 1 more comment
  • m_rolleri Aug 08, 2008
    Opps forgot the "other" problem... TV will not respond to remote, can't adjust volume, change channel or even turn the TV off. Try to turn off using the power switch of the TV and will not turn off. In order to get TV to respond need to unplug and plug back in.
    Both problems exisited before the upgrade. But the not responding to the remote just started about a week ago. We have a another repair person coming next week who stated that maybe the lamp ballister may be bad. Hopefully the 5th visit will be the charm to get this TV fixed.
    I don't think the upgrade was done correctly. He plugged in a flash drive to the USB port and the lights on front of the TV blinked red , orange for some time. When I asked how would he know when the upgrade was completed he stated that the lights would stop flashing and a solid green light would appear. That never happened - after 15 minutes he removed the flash drive turned the TV on and within 5 minutes it shut off by itself. He did the upgrade again and this he said that when the upgrade is completed the orange light will flash. So after 10 minutes he removed the flash drive left. 20 minutes after he left the problem returned -- TV would not respond to remote and could not turn off using the remote or power switch on TV. And within 1 hour the turning off/on returned.
    Thanks for you advice
  • akramc Aug 23, 2008
    Bought this TV in 2006 from Circuit City . When turn TV on power light blinks green for about 15 seconds then it changes to blink red for 10 seconds and disapear for 20 second and blink again red and keep doing this for ever. I have replaced the lamp and still doing the same.
  • 51 Answers
The software still needs to upgraded properly. If you unplug the TV for 5 Min the plug back in and turn does it work
Posted on Dec 04, 2009
    Problem Solver:
  • 7 Answers
I've solved that problem, found cold solder on the board. a loose connection.
Posted on May 09, 2010
Any idea on where i may obtain the upgrade software?
Posted on Dec 28, 2009
    Scholar:
  • 52 Answers
Well your orgional post sounds like the set was overheating.. The second comment sounds like you have a bad firmware installed.. So who ever upgraded it, didnt do it correctly or the main control board for the tv is shot. Did you have the same no responce prior to the upgraded software?
Posted on Aug 08, 2008
I have a kdf-e42a10 tv no sound or picture red light flashes continuous
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Sony KDF-E42A10 42 in. LCD Television
Toshiba 42dpc85 won't turn on, red light blinking continuously
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Dec 08, 2013 | Sony KDF-E42A10 42 in. LCD Television
Sony kdf-E42A10 red light blinking
see other solution and remove and inspect lamp.
The set will shut down if lamp fails to come on.
Mar 12, 2012 | Sony KDF-42WE655 Television
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Apr 28, 2011 | Sony KDF-E42A10 42 in. LCD Television
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
799 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
