Question about Pioneer Audio Players & Recorders
How do i reset my Pioneer SX 316 Surround Sound System. i lost the owners manual.
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Posted on Sep 09, 2008
check the attached service manual.
H appears normal and L appears to be defect.
also see page 88 to troubleshoot further Pioneer SX 316 Service Manual
Apr 05, 2016 | Pioneer Sx-316 Audio Multi-channel...
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here:
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Pioneer receiver sx 316 shuts off after a few moments of being turned on
Mine is having this problem now.
Tried re-inserting the speaker wires.
Tried resetting before it shuts off.
Tried disassembling but solder joins are still nice.
It still shuts off soon after power up. Time to spend money? :(
Sep 08, 2012 | Pioneer Sx-316 Audio Multi-channel...
Dead no power.. checked main fuse, worked fine last night, went to turn it on today and nothing. its a sx-316 not sx-315, I say this because it tells me this is not a valid model#, but sx316 is printed on...
Check the resistance of the primary on the main power transformer, (with power off) should be 1-3 ohms. If open you need a new transformer.
If good turn it on and check for ac voltage (120v) there.
Nov 26, 2009 | Pioneer SX-315
No sound from my speakers
Check your Surround Settings (Make sure you are in Full surround and not 2 ch) as well as your Input Source Remember the Surround Speakers will not give you a Full Audio Output it will only give you "background noise"
Sep 27, 2008 | Pioneer SX-315
Distorted sound coming out of SW channel only
try turnind down the sub from the amp itself it might be putting out more volts than the subs input can handle check your standing wave feature to make sure the trim is not up too high
Jan 13, 2008 | Pioneer SX-315
891 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
