Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Turn off closed caption.
The closed caption is on. I dont have a remote. Is there a way to turn it off?
4 Suggested Answers
  • 319 Answers
SOURCE: turning off closed captioning
You should be able to turn off caption from remote. Go to menu for this
Posted on Apr 21, 2008
SOURCE: Cant turn off closed caption
I have this same problem...TC-P42X1...can't turn off the closed captioning
Posted on Aug 29, 2009
SD Tech
  • 14553 Answers
SOURCE: how do i turn on the closed caption if i dont have the original remote to a PT-52lcx35
Most Panasonic TV remotes (not real expensive on EBAY or from Panasonic) will work on several models for this feature.
Posted on Nov 01, 2012
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
I am trying to turn on my closed captioning on my 19'' orion tv but dont see it... how do i turn it on
Usually you can turn on the closed captioning from the remote. There (should) be a button labeled "cc" that you just need to press once or twice until you get the closed captioning style you want. If your remote doesn't have this button, or if you don't have a remote, you could try two things. First, you could try (i'm not sure if this would work) going into the tv menu itself and searching for the closed captioning part, or you could just go out and buy a universal remote that has the "cc" key. I hope this helps! Sincerely, Der Strom
Apr 08, 2010 | Televison & Video
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
CLOSED CAPTION
Unplug the TV, let it sit for a few minutes, then plug t i again. That should reset it. If not, you'll probably have to order the remote from the company to turn it iff.
Dec 28, 2008 | Insignia IS-LCDTV32 32 in. Television
Closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
May 10, 2008 | Durabrand DWT1905 TV
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Closed Caption
If you dont have the original remote, its going to be kinda hard, as universals wont work on this funtion on this set. The original remote has a button marked "CC" toward the bottom of the remote. Maybe you can borrowe on from a friend or a local sales store just so you can turn off the closed caption.. You can purchae a replace remote that is exactly the same as the original at http://www.remotes.com and enter your model number.
Sep 14, 2006 | Philips Magnavox MT1905B 19" TV
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
