Question about Sony Audio Players & Recorders
SONY AUDIO MODEL HCDZX50MD
AFTER YOU TURN UNIT ON, IT GOES BACK INTO STANDBY. DOES ANYONE HAVE A SCHEMATIC DIGRAM OR SERVICE MANUAL FOR THIS UNIT?
    Problem Solver:
  • 15 Answers
Disconnect the audio output IC from the board an listen to hear if the output relay click, if it does the audio output is faulty replace it..
Posted on Aug 10, 2008
Sont CMT-NEZ5 won't stay on, standby light blinks
Hello
I haven't the schematic diagram to your set at present. If you send the schematic you have with me now, I'll refer it and will give you further assistance. OK.
gopalan.gopakumar327@gmail.com
Nov 10, 2011 | Sony CMT-NE5 CD Shelf System
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Screen will begin turning blue, then go black and standby timer light blinks 8x in sequence. I can repower and screen will come back on temporarily. Tv may work for days then suddenly start doing again....
hello ,Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 10, 2009 | Sony KP-51WS500 51" Rear Projection...
Turns off blinks 6 times and turns off blinks eight times
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.good luck
shaun
Aug 22, 2009 | Sony Televison & Video
I need a schematic or service manual for Sony STR-DE345.
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
Feb 19, 2009 | Sony STR-DE345 Receiver
Sony STR-DE315 will not power up
Do you have its service manual to go further in unit? let me know as schematic is necessary to rectify its problem of no power.
Regards,
Sep 10, 2008 | Sony STR-DE315 Receiver
KV-32FS120 Standby Timer blinks nine times
what exact model number of your Sony tv is? I need it to arrange the service manual or schematics.
Aug 12, 2008 | Sony KP-57WS520 57" Rear Projection...
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Dec 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Blinking 8x's
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. If your not a tech and have no solid state repair experience, play it safe and call out a pro to assist you in this type of repair.
Jun 29, 2007 | Sony KP-46WT500 46" Rear Projection...
393 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
