Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
Sonic air light keeps blinking even after cleaning
  • richard517 Aug 11, 2008
    I have the same problem.
  • m1acres Aug 22, 2008
    my red light needs cleaning keeps blinking although I have cleaned the machine very well. What is the problem? and can I fix it because I am very handy with numerous tools?? Mark
      email me a solution at        m1acres@aol.com
  • 2,794 Answers
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Posted on Aug 27, 2008
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
Oct 20, 2014 | Oreck XL Professional Air Purifier
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents..
take out the bulb and clean the whole inside as best as you can..
and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps
Jun 11, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
Model s1871sharper image room purifiler. keeps blinking that it is not clean when i just cleaned it
Just check to make sure none of the wires at the front of the unit broken and shorted to an adjacent plate.
Wash the electrode unit with an acidic cleaner like Formula 409, and let it dry, and dust out the cabinet with clean compressed air if you have a source. While this will not alleviate all the red indicator indicators, it will address most of them. The others, you may just decide to live with because the air filer is still filtering/ionizing even if it does indicate it needs cleaning..
Sep 28, 2012 | Air Purifiers
Hi,I cleaned the plates on my sharper image quadra air purifier and the inside of it to.But the red light keeps blinking on the cleaning overdue light,how do i get it to stop blinking?.It never did this...
I've had a problem with the contacts being broken. there are little contacts on the bottom of the plates that spring out when it is reinstalled. they push against 2 wires inside teh unit. make sure they have good contact...
Sep 06, 2010 | Sharper Image Ionic Breeze 3.0 Air...
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Aug 01, 2010 | Sharper Image Hybrid GP (SI724) Air...
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic breeze quadra constantly blinking cleaning overdue, evenghough it is clean.
If it still works after you cleaned it, consider yourself lucky. If light blinking bothers you, just put a piece of black electrical tape over it and enjoy it. That unit has been driving me nuts for years. I cleaned mine and now it doesn't work at all. A blinking light I could put up with, with a little tape. Enjoy it because it still works.
Apr 05, 2009 | Sharper Image Professional Plus Ionic...
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
201 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
