Question about Kirby Generation 3 Bagged Upright Vacuum
Belt problem My belt broke. I put a new belt in, followed the instructions, seemed to be right but as I started using the vaccuum, it starting smelling like burnt rubber. The belt was extremely hot. Took it apart, tried again and the same thing happened. Please help me!!!!
Get the old lady to use a dustpan and brush instead SORTED
Posted on Oct 09, 2008
  • 357 Answers
Here is the link to the detailed instructions for belt changing. When you take the brushroll out, make sure that the brushroll spins freely. If it doesn't it will burn up your belts and needs to be replaced.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Posted on Aug 28, 2008
  • 4 Answers
The brush is jammed most likely or not in correctly
Posted on Aug 08, 2008
Put belts on a Bissell pro heat 2x
Call the Bissell Consumer Care at 1-800-237-7691 something doesn't sound right. Are you sure you followed the detailed install instructions that should have come with the new belts? I'd check that first and if you did then call them.
Jan 17, 2015 | Bissell 1699 ProHeat Clear View Upright...
Vaccuum cleaner brush belt broke. I'm looking for a replacement, but the only number on the belt is S3M 267
Try here:
Dirt Devil Platinum Force Vacuum Belt - S3M-267 Part Number: 1-912425-600 Or try WALMART.
Dec 15, 2010 | Vacuums
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
Can't remove black brush arm on bissell model #8910
The bar rides in sockets at either end of the bar. Look at it carefully,; it is probably not quite right. Ease it back out by wiggling it and try prying gently with a small screwdriver. Once out, look at the ends, and match them back up with the sockets.
--W/D--
Jul 28, 2009 | Vacuums
I'm using (or WAS using) a Eureka ''the boss'' model 8803. The belt broke, no biggie, so I replaced it with a Eureka model U belt, the problem is when I put the new belt on and turn on the vaccuum, the...
First, make sure you have the right belt, second, i am thinking that you are not lineing the roller up right, it will only fit one way. look at the ends of the roller and the grooves where it slides in, you should be able to see clearly how it goes.
Jul 26, 2009 | Vacuums
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Kirby Generation 3 Bagged Upright Vacuum Logo
173 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
