Question about HP Pavilion zd8000 Notebook
Do you think you can help me ?
Zd8000 wifi problem, i went into the control panel and tried to run broadcom wireless utility, but first it gave me an error saying 'internal configuration inconsistent' i kind of overrode that and it opened up. now it passes all the tests and all the boxes are clicked for example the enable radio and stuff.
but still no icon in the taskbar and no wifi network
  • 186 Answers
First, try removing and reinstalling the Wireless Card Drivers from the Device Manager by following the instructions below :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to Network Adapters to expand the tree.
Now, right click on the Broadcom Wireless adapter entry and select Uninstall.
Now, restart the Notebook and download the Wireless card drives for your notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp33001-33500/sp33008.exe
Save the file in the hard drive and double click once it is saved to install the Drivers.
Restart the Notebook after the installing is completed.
If the issue remains, try reinstalling the HP Wireless Assistant.
Uninstall it from the Add or remove programs in the Control Panel.
Download and save the HP Wireless Assistant application which is available from the link below :
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30637.exe
Install it by double clicking it and restart once the installation is completed.
This should resolve the issue.
Posted on Aug 14, 2008
SOURCE:
How to turn on hp zd8000 wireless switch
old relic (retired and legacy) Pentium 4 dog.
wow no details at all.
what switch, where? the HP special one for wifi?
what OS, XP? ? windows XP the dead virus magnet PC?
the switch needs the HP driver to work.
use ethernet cable instead.
If the full Wlan wifi driver is installed, from HP
all that works.
Broadcom 802.11b/g Wireless LAN 54G
HP has no support for this old PC
MS has no support for XP or Vista. no OS stated by you at all.
the card is so ask Broadcom for you driver.
that the last resort.
BCM94318mpg
AT BROADCOM, it shows OBSOLETE
i see lots of folks on line begging for this cards driver.
and no success now.2018
id up grade it, to newest WPA2 card, lacking the KRACK
venerability !
Jan 01, 2018 | HP Computers & Internet
Wireless driver install issue
There is also Atheros WiFi driver for your lap top, so You may try that one, it's from the official Packard Bell web site
http://global-download.packardbell.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Atheros_9.0.0.173_W7x64_A.zip?acerid=634145041043920996&Step1=Notebook&Step2=EasyNote&Step3=EN%20TM80&OS=721&LC=en&BC=Packard%20Bell&SC=EMEA_27P
this is the link to Your driver
Jun 09, 2012 | Packard Bell Computers & Internet
I have an acer aspire 5733. I have been trying to connect to a wireless connection. It has no button to switch the wireless on, l use the function key plus wireless. When I press the button it does no show...
Wifi needs utility to scan the hotspots before you can connect to any one of them. Utility maybe in control panel as wireless(not IR). Then you can see the wifi icon in system tray next to the time and date.
Feb 29, 2012 | Acer Computers & Internet
Hi, I have a HP Compaq nx6110 with Broadcom wireless adapter, and I have a Wireless problem. I've recently reinstalled my OS, it's a Win XP SP3, and ever since my wireless adapter wont start, it...
  1. Make sure to press the WiFi button on your notebook. You should see a blue light if your WiFi adapter is on.
  2. If that doesn't work, download and install the latest version of the wireless adapter driver.
    http://bit.ly/lrDIcL
May 07, 2011 | Computers & Internet
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Need Network Controller 4 both Compaq Presario 2100 2500 Laptops
You have to install the WiFi card with an Installer before it is recognized by device manager... go to the link below, and download the WiFi driver and install as Administrator. You will need to know your exact model number to do so.. Do NOT just get a WiFi driver that will NOT work, you must get installer version.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Compaq+Presario+PC+Notebook&submit.x=4&submit.y=8
Mar 05, 2010 | Compaq Presario Notebook
Broadcom getting uninstalled automatically
Hi There,
I don't know if this is the same problem you are having but one of the staff from my office was bumping the switch on the side of his laptop and turning off wireless support. When you look in the device manager you don't see anything because it is turned off. He would bump it again in a few days and it would magically come back. Not all laptops have a switch like this. Some have a function key combination you press to turn wireless on and off but you can't still trigger that by accident but not as easily as a button on the side of the case.
Hope this helps.
Jul 11, 2009 | Broadcom BCM5704 Network Adapter
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
Wifi will not come on
You can turn the wireless on from the control panel. In control panel you will find HP wireless assistant with which you can turn on the wireless.However, the issue could be with the wireless driver or quick launch buttons.I will provide you the drivers for the notebook zv6000. Download and install them on the notebook. HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
Broadcom WLAN Network Adapters Driver
ftp://ftp.hp.com/pub/softpaq/sp30001-30500/SP30379.exe
Try the above drivers and the wireless will start working normally.
Dec 18, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavilion zd8000 Notebook Logo
336 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
