My computer says no audio device and its connected
    Scholar:
  • 144 Answers
Reinstall the drivers and restart the PC.
Check for driver updates on manufacturers site.
Posted on Aug 08, 2008
I have no sound at all, not sure wot to do. says something about no audio devices are installed,
hello jenz8860, try open device manager (run type devmgmt.msc), if u find question mark on your audio device then u need to install audio driver.
to install audio driver use motherboard driver, insert to CDROM, right click the audio device on device manager then update driver. choose recommended option then click next and follow the instruction. your audio device will automatically installed. if it success installed then u need to restart your PC.
if there is no problem in device manager, high possibility it's on hardware problem, try to see cable connection between speaker and PC (use back panel connection, don't use front panel audio, this to make sure the connection is good), if it's ok then mostly problem came from your speaker. try to use another speaker.
hope this useful, regards.
Aug 26, 2011 | Audio Players & Recorders
How to install audio output device to my computer?
connect the audio output device to the audio out 3.5mm jack of your sound card, it is usually lime-green in color.
Apr 08, 2011 | Computers & Internet
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
I connected to the computer with a blutooth device , and now i cant hear any audio from computer
go to control panel -- open sound and audio devices - open audio tab and select the default device back to realtek(motherboard) device.
When you installed bluetooth it automatically changed the default device settings.
Dec 28, 2010 | Jabra BT2050 Bluetooth Headset
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
I have reconnected my Philips MMS 321 speakers to my computer and my computer does not even acknoledge they are connected. My I put my Magicjack on this computer, it tookover as my default audio source....
go to "Start/Control Panel/Sounds and Audio Devices/Audio" and correct set the "Sound Playback Default Device" and "Sound Recording Default Device" settings to be your computer speakers (i.e. computer sound card device).
Aug 27, 2010 | Philips MMS 321 Computer Speakers
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
How do I send audio files with bluetooth?
Do you mean you want to tranfer audio files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Dec 05, 2008 | LG KU990 Viewty
    No sound device found
    check for devices in "other devices" in Device manager
    Oct 22, 2007 | Computers & Internet
     Grubhead
    Grubhead
