Question about Yamaha RX-V2300 Receiver
Center speaker Hello, I have my receiver set up for zone 2 which is located on my patio. When listening to music in the house, the center speaker doesn't play when zone 2 is on. When I turn zone 2 off, the center speaker kicks on. Drivin' me nuts. Any suggestions? Thanks, John
    President:
  • 624 Answers
When you turn on zone 2 you are in stereo mode. The center speaker and the rear speakers will not function in stereo mode.
Try turning on zone 2 and then switch the surround mode after that and see if it helps. If it turns the zone 2 speakers off when you do that, then your unit does not support what you want it to do. Center speakers only work in listening modes other than stereo.
Most A/V receivers are designed for watching movies and they did not take this use into consideration because zone 2 would normally be in another room such as the way you have yours set up. If somebody is watching a movie in one room they would not need to hear it in another room. You would think that the designers, who are very talented to be able to come up with these type of units, would have just a little more imagination on how people would be using the equipment. Go figure!
If your receiver has a 5 or 7 channel stereo mode, it may work then. You can try, but I don't think it will help.
I have even seen some receivers that have the center channel amp being used for the zone 2 output as well. It just switches what speaker output jacks it goes to with a couple of relays which makes it impossible to use the center and zone 2 at the same time.
I guess they are just being cheap by not putting another output channel in the unit and sharing the one they have.
Why would anybody want to use the center and the zone 2 at the same time???? Sad, isn't it.
Hard to believe that such a nice receiver would have such a rediculous limit designed right into it. But they really do design them like that.
Let me know if you need more help.
Dave
Posted on Aug 08, 2008
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
When I set my Yamaha rx-v363 amplifier to 5ch Music Enhancer all my speakers (including the sub woofer) work fine except for the center speaker. I can't even adjust the center volume on the amp (but I can...
The receiver automatically pick the best configuration for the source audio. Most music is 2 channels being up-sampled to 4 channels. (Sub-out is separate.)
Mar 22, 2011 | Yamaha RX-V363 Receiver
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
B speaker setup problem
Why don't you set it Zone 2 then you could listen to the radio outside and still watch tv inside. You can turn it on and off just like a and b speakers.
Jul 07, 2009 | Yamaha RX-V663 Receiver
Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Mar 17, 2009 | Sony Audio Players & Recorders
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Zone 2 Setup
Turn Zone 2 off. Speaker selector is made through pressing the dial below the volume dial
Mar 24, 2008 | Denon AVR588 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha RX-V2300 Receiver Logo
147 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
