Question about Canon PowerShot G7 Digital Camera
Green Light Won't Turn Off
I can't get the green light on the front of my canon powershot G7 to turn off. I believe it is the AF assist beam. What's wrong?
  • Tony Jubb Sep 18, 2008
    I have exactly the same problem with my G9 camera. Even though I select the AF Assist beam in the menu and turn it off the beam still comes on. My 1 year old grandson now squints everytime I point my camera at him and there's nothing I can do to prevent it!
Turn off the red eye reduction mate,
Posted on Sep 27, 2008
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Why is my led screen blurry in low light before I take a picture?
It sounds like your camera settings have the( AF Assist Beam) on Off? That is the Amber Color light you see when you half press the shutter button. If that setting is set to OFF, then the camera can not focus in low light giving you blurry pictures as it can not see any light to assist the camera on focusing. If you turn on the (AF Assist Beam) to on, they when you press the shutter button half ways down you will see a Reddish/ Amber light, that light helps the camera find a focus point, giving you a slightly better low light photo.
Jun 09, 2014 | Canon PowerShot SD1400 IS IXUS 130...
Flashes but no picture is captured
please read this>
AF /assist beam is set to OFF,, turn on
2) camera move when the shutter button is pressed.
3) subject is out of focal range
4) the subject is hard to focus on
in short read owner manual very well.
God bless you
Sep 27, 2012 | Canon PowerShot A470 Digital Camera
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
When I take pictures it, the picture turns out all blurry. Is there any reason why?
  • Be careful not to block the AF-assist Beam with fingers or other items.
  • Check the shooting mode to make sure Macro or a Macro setting is not being used.
  • Move the camera away from the subject slightly.
  • Preventing camera shake
  • Preventing camera shake using a PowerShot camera.
  • The PowerShot SD600 requires repair service.
  • Tips for taking better pictures in low light or night time conditions.
  • Use a tripod or other stable support
  • What to do if your camera does not focus on the subject.
  • Jul 29, 2010 | Canon PowerShot SD600 Digital Camera
    Turn off focus assist beam on Nikon
    Custom Setting Menu A, autofocus, setting A3 "Built-in AF-assist illuminator".
    174 in my D90 manual.
    "Choose whether the built-in AF-assist illuminator lights to assist the focus operation when lighting is poor"
    Jul 06, 2009 | Nikon D90 Body Only Digital Camera
    Af assist on canon flash 580exii not working
    check Custom Functions of Camera and Flash it can be turned off in both locations
    Jun 13, 2009 | Canon Speedlite 580EX II TTL Flash
    Turning af beam off
    The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
    Apr 21, 2008 | Canon PowerShot A520 Digital Camera
    Focus light always orange...never green
    that's a problem? the focus light does *NOT* turn green in this cam
    Mar 14, 2008 | Canon PowerShot A95 Digital Camera
    Canon PowerShot G7 Digital Camera Logo
    223 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
