Question about HP OfficeJet 6210 All-In-One InkJet Printer
Hp officejet 6210
My printer is saying off line. How do I get it back on and printing?
    Novelist:
  • 106 Answers
In order to set back the printer to online, here are the steps that i want you to do.
1. Right click the printer ICON
2. CHoose option, USE PRINTER ONLINE.
3. Try printing again, that should work.
Goodluck.
adonscott
Posted on Aug 08, 2008
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
tipstir
  • 67 Answers
SOURCE: HP officejet 6210.
Put the printer in the mode for changing the carts. Take out the Black ink car and clean off the heads on it. Looks like brown in color it's on the cart at the bottom To clean use paper towel with cold water never use warm or hot. Clean the area where the in rest in the printer also if you can reach it. The noise you hear is that the cart didn't go back in the right position. You have to be cart not to force these carts out as everything in this printer is made of plastic.
Posted on Jul 23, 2008
dirinda89
  • 214 Answers
SOURCE: INSTALL PRINTER WITHOUT DISK HP OFFICEJET 6210
Here's a link to download the drivers for the 6210. If this helps, plz rate this as 'fixa'. If you have more questions leave a comment & I'll be happy to help. Thank you kindly.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-43586-1&lc=en&cc=us&dlc=en&product=421991&os=228
Posted on Feb 22, 2009
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    rsmith972278
    • 160 Answers
    SOURCE: HP Officejet 6210 will print but with terrible clicking noise
    Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
    Best of Luck,
    RSMITH972278
    Posted on Oct 12, 2009
    Can the ink cartridge HP 98 work on a 6210 HP Office jet?
    No, it can't
    The HP OfficeJet 6210 works with the following print cartridges:
    Black: 94
    Color: 95, 97
    Photo: 99
    Source: http://www.shopping.hp.com/supmodel/product/Q5801A
    TechSaver!
    Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
    I have the HP Officejet 6210, it prints but will not scan
    If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
    Dec 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    How to check ink level on hp officejet 6210 all-in-one printer
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Various lines are cut off when printing
    could be the print heads have you contacted hp support @ 1-800-hp-invent (1-800-474-6836)
    Jan 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    HP Officejet 6210 All-in-One, I want it to print out a conformation page saying that a fax was sent or not. Is this possible?
    You will need to do this on the caroll panel tell you get to fax set up then slect confromasion or what ever it will say the slect what type ofconfromsion you wnt for future faxes and say ok.
    Jan 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    HP Officejet 6210 All in one scanning problem
    just remove old driver from ADD REMOVE PROGRAMME AND THEN RE INSTALL YOUR PRINTER DRIVER AGAIN.
    Jun 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    All in one
    i have a hp officejet 6210 all in one and my printed want receive fax what is the problem. from mary
    Jun 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Owners manual for HP OfficeJet 6210 All-in-One
    If I give you the link to download a HP OfficeJet 6210 All-in-One manual then I'd say thats FixYa
    Nov 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    53 people viewed this question
    Ben Johnson
