I scanned an insurance quote from gas repair expert,he had quite a few spelling errors in his quote.I thought I could correct his spelling errors with OCR on my Canon MP390 from the Toolbox section under OCR scan to make it look more presentable, but after many attempts found I could'nt do it. Could you help please. My email address is toby777@tpg.com.au
Thank you for your reply,my next door neighbor is a computer tech who was'nt home at time when I needed the help,I will contact him.
Many thanks, Trevor
Posted on Aug 08, 2008
Is struktur? of following sentece correct? "New challenges and successes are awaiting for you in high school."
Not quite, the insertion of 'for' is incorrect. It should be
"New challenges and successes are awaiting you in high school."
You spelled 'structure' incorrectly.
You spelled 'sentence' incorrectly.
The period should be AFTER the double quote;
are awaiting you in high school". The period finishes the line or sentence.
Number one tip, always proof read before pressing 'send'.
Apart from that, all good :>)
Aug 27, 2017 | Computers & Internet
Tip
BitDefender Total Security Virus Scan locks or slows down your PC - Follow this...
I see a lot of people complaining that their PC/laptop slows down or even completely stops responding when they run a virus scan or a deep scan on Bit-defender. There is a simple fix to this. All you have to do is change a few things in the scan properties section on Bit-defender as shown below. <br /> First of all you have to get into "Expert Mode" <br /> <br /> By default, Bit-defender starts in to "Novice Mode" <br /> <br /> Click on Settings as shown in the image below <br /> <br /> <img src="drgirish_13.JPG" /><br /> <br /> Next, click on the small arrow next to novice mode and select "Expert Mode" and then APPLY <br /> <img src="drgirish_14.JPG" /><br /> <br /> <br /> The new window that open is "Expert Mode" :) <br /> <img src="drgirish_15.JPG" /><br /> <br /> <br /> Now, Click on AntiVirus, then Virus Scan. Right click on 'Deep System Scan' (or any other type of scan that is giving you the problem) and select Properties. <img src="drgirish_16.JPG" /><br /> <br /> <br /> In the 'Properties' Box make sure that the 'Run the task with low proirity' is CHECKED !<img src="drgirish_17.JPG" /> <br /> <br /> Apply the settings and close all the windows. Bitdefender wont take up all your Laptops resources when it runs a scan. <br /> Thank you for reading this tip. <br /> Please let us know if this was helpful to you. Thank you
on Apr 18, 2011 | Computers & Internet
The piolet turns on the heat doesnt turn on
In most gas appliances It could be caused by defective igniter or main valve or control board or dirty nozzle or gas line issue .Use step by step troubleshooting procedure
For Best safety reason and prevent dangerous consequences and prevent of any hazards of fire and complication with home insurance companies and most important personal safety reason when it comes any gas or propane appliance repair it is best practice to contact insured and bonded local expert gas appliances service centre for best safety reason .
Mar 23, 2013 | Kenmore 400 6943 Dryer
Dryer gets hot then gets cold
Could be plugged vent or It could be caused by defective igniter or main valve or control board or dirty nozzle or gas line issue .Use step by step troubleshooting procedure
For Best safety reason and prevent dangerous consequences and prevent of any hazards of fire and complication with home insurance companies and most important personal safety reason when it comes any gas or propane appliance repair, it is best practice to contact insured and bonded local expert gas appliances service centre for best safety reason .
Jun 23, 2012 | Kenmore 400 6943 Dryer
Rheems Power Vent Model 42vp50fw Manufactured 3/08\r\n The gas comes on but will not stay lit. I have replaced the Combination Gas Control and igniter and heat sensor. Error code comes up as an igintion...
Intellivent gas valve shows AB and vacation error lights:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
The igniter and flame sensor have to be positioned correctly:
http://waterheatertimer.org/pdf/Hot-surface-igniter-troubleshoot.pdf
Check electrical outlet with circuit analyzer, and test that unit is receiving 110Volts
Intellivent gas control must be grounded.
Check that gas control is getting 24volts.
Check for air in gas line and low gas pressure.
Following links offer troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 10, 2011 | Rheem Water Heaters
I took my 2000 Odyssey into the dealer to check the transmission. They found that the idle error control valve was bad, even though the van had been idling just fine. We declined repair, since we were...
I assure you they probally picked up on the problem while checking the trans. they would've used the Honda scan tool and checked any engine malfuntions before evaluating the transmission. you can, however, clean the idle/air control valve by removing it from the throttle body and using some air-intake cleaner on it. the cleaner is available at local parts stores. you may also want to clean the throttle plate with the cleaner to insure it is not sticking to cause the idle problem.
Jul 28, 2011 | 2000 Honda Odyssey
I get a reading Device Monitor Application has encountered a problem and needs to close. The word application is spelt wrong, is this a genuine message
Hello :)
It does sound a little odd doesn't it ? Large companies letting simple spelling mistakes get through in such prominent places, but i have noticed quite a few little errors like this slipping through.
As the item is having a problem, it may be best to detach the printer, uninstall the drivers and any applications that came with that printer, restart the computer, and restart again all from scratch.
As that kind of error report isn't seen a lot, most companies would never concern themselves with correcting a spelling mistake, it can cost far more than expected for a software engineer to make just one correction like that.
It's good that you noticed it though, as with many other kinds of software, it can indicate a cheaply created spyware or virus program pretending to be legitimate.
I hope that information is of some help :)
Mar 18, 2011 | Lexmark X5150 All-In-One InkJet Printer
My dryer is starting a cycle but no hot air to dry the clothes. It's working but not drying.(it's a gas dryer) Thank you
In most gas appliances It could be caused by defective igniters or main valve or control board or dirty nozzle or dirty gas line issue .Use step by step troubleshooting procedure
Jan 10, 2011 | Kenmore 400 6943 Dryer
How do u fix coolpix nikons lens error
lens error problems are unfortunately quit common. There are quite a few error codes and they all mean different things.
This blog will give you more on it: http://www.teleplancamerarepair.com/camera-repair-blog/search.aspx?q=error%20code
And they can repair it https://www.teleplancamerarepair.com/quote/cart.asp?iProbID=6&mo=714
and includes a camera cleaning
Jul 13, 2010 | Nikon COOLPIX S230 Digital Camera
k24674
jasbo
jasbo
