Question about Denon AVR-1403 Receiver
Unit switches itself off
Unit is connected to tv and dvd player.
unit comes on for a couple of seconds then switches itself off and standby light flashes except if switched offf with remote control when light does not blink.
No sound at all; the kids are getting restless!!
  • thelij Aug 08, 2008
    Thanks very much for your prompt and comprehensive response.
    I've tried unplugging the speakers and its still switching off so I think i need a technician.
    Much appreciated.
  • mosesmarks Nov 05, 2008
    I have the same problem. I removed all the speakers and connections but still having the same error. I have a multi-meter, soldering iron and some background in electronics. May I know the procedure to troubleshoot.
    Thank you.
    Big Mo
  • 624 Answers
What you are describing is the protect mode. These Denon receivers go into the protect mode for several different reasons.
Bad speaker connected - disconnect all the speakers and see if it stays on then when turned on. Disconnect speakers with power off. If it stays on then you need to find what speaker is bad and get it repaired or replaced. You can figure it out by connecting one speaker at a time with the power off and then turn it on. If it stays on, the speaker just connected is good, connect another speaker and try again. When you get to a speaker that causes it to go into protect you have found your bad speaker. Always turn unit off in between when connecting speakers. If the receiver turns off with all speakers disconnected you have another problem which will need to be diagnosed by a service center unless you have the proper tools and some electronic troubleshooting knowledge.
There are a couple of other reasons why these Denon's go into protect. A output channel is bad, a voltage regulator is bad, a supply resistor is open. Those are the 3 most common reasons for these.
I work at an authorized Denon repair center and fix a few of these every week. Unless it is a bad speaker it will require a lot of work. They are good receivers and normally worth the cost it would require for repair. Replacing the unit with another one of equal quality will almost always cost at least double the repair cost. There is no way to know just what the repair cost would be without troubleshooting it and then knowing exactly what parts need to be replaced. My shop would charge anywhere from $95 to $250 for this symptom, it just depends on which of the 3 most common problems is causing it.
If you have at least a multimeter and know how to use it, I can helpp you with figuring that out. If it has a blown channel the cost is the highest. The other 2 common problems only require 1 part each, a resistor which is less than a dollar, and the voltage regulator which costs only a couple of dollars. The blown channel requires many parts to be replaced and takes much longer.
Let me know if you need more help,
Posted on Aug 08, 2008
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Intermitent start up
my friend had a similar problem with a panasonic combo unit it needed resetting what we did was hold the power button on the unit for about ten seconds we had to do it a few times but eventually it reset itself then went into standby mode its worth a try hope this helps regards JIm
Apr 29, 2009 | Panasonic DMR-E85H DVD Recorder
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
Philips DVDR610. When in standby switches on briefly
Hide all remotes from the line of sight of the unit and see if this helps....accordianman
Feb 22, 2008 | JVC XV-N212 DVD Player
DVD stuck inside, player won't turn on, standby light does NOT flash
test the capacitor with a meter to make sure it has the value stated on it.
the work on this unit is quickly exceeding its present value, most likely.
consider upgrading to a higher resolution unit if the fix is more expensive in parts and time than a new unit costs.
good luck
Dec 29, 2007 | Philips DVP642 DVD Player
Unit turns itself on in standby mode
This can be a very irritating problem. Happened to me too. The only thing to do is after you turn off the unit with the remote, go to the unit and physically turn off the power to the unit with the manual Power on/off switch on the left side of the unit. Nothing else works.
Jan 14, 2007 | Koss KD365 DVD Player
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Denon AVR-1403 Receiver Logo
270 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
