Question about LG Washing Machines
LG WAHING MACHINE MODEL NoWF-F7511FN
WASH AND SPIN LIGHT BLINKING AND MACHINE IS GIVING BEEP SOUND.TRYING TO WASH IN TURBO- FUZZY OPTION BUT AFTER TAKING A ROUND IT STOPS AND STARTS GIVING BEEP WITH SPIN AND WASH LIGHT
jsrock516
  • 5911 Answers
SOURCE: MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Posted on Apr 29, 2007
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
SOURCE: LG WF-T1022TP Fuzzy Logic
Dear Sir¨
The problem with my machine WF-T1022TP is the fallow:
The pump not run correctly, for these reason, I need the manual of operation, please send this document to my e-mail: jmar440@gmail.com
thank you
Regards
Javier
Posted on Oct 04, 2009
SOURCE: My LG Fuzzy Logic 6.5KG WFS65A01DCT - The wash and
My LG washing machine WFS65A01DCT shuts off with the error signal that the door is open when it's not. How do I disable that signal?
Posted on Dec 19, 2010
On my fuzzy logic 6.5 top load I keep getting a beep and the wash and spin indicators blinking simulatinously. What could be the reason for this, how can I fix this?
I had the same problem. I lost the magnet in the lid cover. So, I put a magnet as shown in the picture (blue and red color one). It working now!!!!
May 24, 2014 | LG WM-2077C Front Load Washer
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
My LG Fuzzy Logic 6.5KG WFS65A01DCT - The wash and spin lights are blinking with a pulsing sound what do i do?
Feb 13, 2010 | LG Washing Machines
Washing Machines Logo
213 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
