Question about Toshiba Computers & Internet
I have a Toshiba Satellite A305-s6864. after i play a game on my computer, i shut it off and when i turn it back on, i go on my account and all the colors on my screen just mix up and you dont even understand whats on my screen. it also frezes when the screen gets mixed up.
  • 99 Answers
This seems to be a problem with the graphics driver. Find out what graphics chip you have, and download the latest driver.
From what I see you have an ATI Radeon HD 3470 Graphics
if this is true, go here:
http://ati.amd.com/support/driver.html
Posted on Aug 08, 2008
My toshiba satellite a305 s6864, it is running windows vista home premium 64 bits the whole system is getting to freezed states instantly. I can't move my mouse, nor the keyboards responds. I...
I would start by entering the bios using the method below. Try running a hardware scan. It sounds like you could just have a hard drive that is going bad.
F2 key method Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Toshiba Hardware utility method Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below). The Toshiba Hardware utility may be downloaded from the Toshiba support website at http://support.toshiba.com
If the computer is fully off, and/or to avoid having to re-start it (and Windows), use one or the other of the following two methods. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode). If an external keyboard is attached to the notebook (either directly or via a docking station or a port-replicator), disconnect it until you have completed this procedure.
Esc key method Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For Toshiba notebook PCs manufactured before the introduction of Windows XP One or more of the following methods are appropriate:
HWSetup method Run the HWSetup utility from the Windows Control Panel. This utility provides a relatively user-friendly way to change the BIOS settings. Changes to some of the settings will require re-starting the PC (and Windows). HWSetup was pre-installed on all but early Toshiba notebook models. If it doesn't appear as a Control Panel applet on your computer, you may be able to download it from the Toshiba Support website as part of the Toshiba Utilities package for your model.
Esc key method If an external keyboard is attached to the notebook, either directly or via a docking station or a port-replicator, disconnect it. Turn the computer on. Immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode) for this method to work.
http://support.toshiba.com/sscontent?docId=98081013
Sep 25, 2017 | Toshiba Satellite A305-S6864 Notebook
I cant boot up from my cd,after i installed a new wd 80 gb hard drive... i get a message saying that the vendor id dont match,what should i do????
try going into the bios and change the boot priority to cd first then hdd, you may also have to set the jumper on the hdd to master.
May 17, 2011 | Toshiba Satellite A305-S6864 Notebook
I have the Toshiba Satellite A305-S6857, and lately whenever i play music, or watch movies, or videos online the sound and video will skip or become delayed a couple seconds as if the computer is...
you do have something else running in the background and its using the internet, probably spyware or malware. run your anti-spyware program and check, if you don't have one, you need to try "malwarebytes" or "spybot" they are free programs
Mar 19, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
I get a fatal error upon bootup for my toshiba laptop. The error refers to to a hard disk problem based on the following error codes. 0X0000007B 0XFFFFFA6005AF9CO 0XFFFFFFFFC0000034 I have gone into...
windows has corrupted files and can not continue to load "software issue" or there may be bad sectors on the hard drive. To test this! If you have the original recovery disc, try and reload your operational system if successful it proves software problem. If this fails! the hard drive needs to be pulled and tested or use the smart software to test the hardware in the computer, if it fails replace the hard drive.
Jan 17, 2011 | Toshiba Satellite A305-S6864 Notebook
How can i upgrade a305-s6872 videocard.I want to
Toshiba Satellite's are not game machines. Just put up with the error, or get a desktop.
Oct 22, 2009 | Computers & Internet
I forgot my user name password for my Toshiba Satellite A305-S6872. I know...stupid. Never again - i swear.
reboot the computer and restart it in safe mode by pressing F8.select administartor account and then go to control panel -user accounts and then u remove the password.restart the computer again and then put in a passwrd again if u want
Feb 24, 2009 | Toshiba Satellite P105-S6104 Notebook
no problem, glad it worked
Aug 08, 2008 | Computers & Internet
No problem,
Yea, it should be the latest driver for your specific card
The Radeon 3400 series is the one you're looking for.
Computers & Internet Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
