Wondering if you know what pqrt is needed to get the front speaker to work. I was told very early on that someone took off the front panel and cross the connections somehow & it blew out the board that works the volume/speaker on the set. I have been able to bypass the volume problem through my stereo receiver.
The Audio output is on the A board sony part A-1300-550-A if you are looking to replace the board I know where you can get a new replacement A board at the following link, and If you leave them a email and mention that I sent you they may offer you a discount as I do tech support for them. Heres the link leave them a email, see what they say. http://servicemanuals.vstore.ca/
sony ptojection tv model KP-FW51....the last day or so tv does not turn straight on with usuall...
(More)
sony ptojection tv model KP-FW51....the last day or so tv does not turn straight on with usuall green light - Once I use the remote to turn on I get picture ....But the red light flashes continually ?
mitsubishi projection tv picture and sound turn off but the power button remains on with no picture...
(More)
mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be te problem?
panasonic plasma model TH-C42HD18 just tried to have HD DVR installed, experienced purple &...
(More)
panasonic plasma model TH-C42HD18 just tried to have HD DVR installed, experienced purple & Green Horizontal bands about 3" wide in HD only. Comcast says either my TV or electrical interference.
I have a Sony Vega SXRD, 50-inch (I think), LCD TV, Model No. KDS-R50XBR1, Jan 2006. Typically, the...
(More)
I have a Sony Vega SXRD, 50-inch (I think), LCD TV, Model No. KDS-R50XBR1, Jan 2006. Typically, the TV would turn ''on'' and light at the front panel near the ''on'' switch would blink before the TV screen would light up and the blinking light would be a constant light. But this morning, I turned on the TV and the light would blink and the screen would flash on for less than a second and go black. The front panel light would blink four times and than nothing and than blink another four times. The panel would remain black or off. Only when I initially try to turn on the TV, the panel would flash on for just a second and turn black again. The blinking light would continue to blink all day. Any help would be appreciated. I plan to call a Sony repair man. I called a local guy and he took down the model number and asked what happened, charged me $49 and told me he would look into it or research the problem. He was out the door within 10 minutes. I will not repeat that service again!
