Question about Roper Refrigerators
Roper fridge problem
I have a Roper Refrigerator with top freezer (not sure of exact model) It used to have a vacuum sound when you closed the door and it would pull the door closed tighter. It does not do that any more. Is there a vacuum pump somewhere that is accessible? I am also seeing what look like condensation on the top and on the glass containers. Not seeing water in the bottom like you would expect if the drain was plugged. Anyone have any suggestions?
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 08, 2008
Why isn't it cooling correctly?
Good morning Mark.
There are a few general things that can underlie a cooling problem:
A couple of things to think about?
  1. Are both the refrigerator and freezer having trouble, or just one of them? The refrigerator section is usually cooled by circulating air from the freezer into the fridge compartment, using a variable slide vent to manage how much or little air is passed to the fridge part. (This is why sometimes you'll have stuff in one section that seems to get frozen at times - it's sitting right next to the vent). If this vent gets stuck, especially in the closed or mostly closed position, the fridge compartment won't cool enough. the culprit is often that ice has frozen into the mechanism for the vent movement. You'll want to look up a DIY on checking that out. Here is one aimed at Kenmore/Sears/Whirlpool, but it'll no doubt overlap over 90% with your Roper.
Freezer to refrigerator vent frozen 1
There is also a site I can point you to that talks a bit more on possible culprits (with parts for sale, of course)
Roper Refrigerator Freezer is Cold But Refrigerator is Warm
If everything is warm, fridge and freezer both, then you're generally looking for either a dead/worn out / dirty thermostat, that may think the fridge is cooler than it really is, or possibly an issue with the compressor.
Also, if the freezer area is clogged with ice, this can influence the thermostat, and also impair the ability of the coolant to pull heat out of the system - (you have to flow the heat through a big layer of ice, which makes the system less efficient).
You can also look to see if you have a tribe of dust bunnies that have taken up residence on the cooling coils. If so, dust them off with a soft brush or some compressed canned air (or a vacuum cleaner wand)
Last thought - if the cooling fan for the compressor has stopped, failed, or gotten jammed, that will significantly reduce the compressor capability, and burn it out before long. Make sure the fan is spinning when the fridge is plugged in.
Hoping this helps. If you go do any defrosting, avoid doing it with sharp objects, and use some patience. One tiny pinhole in a freezer coil and you're looking at a repair that will almost certainly cost more than the fridge is worth.
Good Luck!
D
Nov 23, 2015 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge door Magnet does not work
do you mean the door seals,if so you may need new ones or you have lost the vacuum in your ff, they are not magnets they feel like it but it is vacuum sealed,,try a ff second hand shop
Mar 27, 2013 | Kenmore 17.5 cu. ft. Top Freezer...
Refrigator with a top freezer freezes up about every 4 weeks
Check the door and seals, does it close and seal properly.
If the seals are letting in warm air, the fridge goes into overtime, hence freezing up.
Its also worth checking that the fridge isn't on too higher setting.
May 10, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
62 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
