Question about Samsung SyncMaster 740N 17" LCD Monitor
Monitor stuck on black, menu buttons not responding
My monitor screen wont turn on basically, the screen was on standbye last night as in i turned the computer off and the screen goes to standbye. I wake thismorning to turn the computer on and the computer works a charm but the screen stays black, the menu bar wont come up however the screen is on with the light blinking, once turned on the light goes constant as if everything is fine however nothing happens. I plugged my girlfriends screen into my computer using only her monitor, my plugs and all and everything works fine :( plz help hehe.
  • 1 more comment
  • benstack Aug 14, 2008
    I am having the same exactly problem but unfortunately the solution offered does not work - any advise?
  • echauner Aug 15, 2008
    I unplugged everything for 30 minutes and when I plugged it in, the power button still just blinks and the screen is black. It worked fine for a year then all of a sudden, black. I have the 204B.
  • Anonymous Sep 25, 2008
    same here, turned it off at night, and on the morning it refused to start. The button shows that it's on, but i have no picture, only black screen. Unplugging it for 30 minutes didn't help, and i need to know if there are other ways to fix this because i can't afford to buy another monitor.
    By the way, it was making a strange high noise for about a week before the problem occured.
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Posted on Sep 27, 2008
    Scholar:
  • 144 Answers
Unplug the monitor from the power for about 30minutes, this will make it "reset" itself and might solve the problem.
If it helps, next time when you shut down the pc turn off the monitor instead of making it go into standby to avoid future problems.
Posted on Aug 08, 2008
SOURCE:
What do I do to get a screen that is frozen on a hp2010i monitor it is asking for language but the cursor on my mouse wont go to the selection
HP Monitor Problem - YouTube
? 1:35
https://www.youtube.com/watch?v=RYLaefQQdDY
Jul 22, 2009 - Uploaded by 7TimeToShine7
So I can use the monitor like I am using now but when themonitor goes to sleep I ... I tried it with a different computer and the monitor was able to re-find the ... How to fix or troubleshoot a blank or black screen not powering up ...
Monitor message" Power Button Lockout" - HP Support Forum
h30434.www3.hp.com > ... > Video/Touch
Feb 2, 2011 - 10 posts
Solved: New HP 23" monitor - HP 2310m Accidentally held down the power button too long; now I can't get the monitor to turn completely off. ... How can I turn the monitoroff completely and clear the message "Power Button ..... 8) · HP PCs - Error Messages Display on a Black Screen during Startup or Boot ...
OSD Lockout on my desktop monitor - HP Support Forum ...
h30434.www3.hp.com > ... > Boot
Dec 25, 2010 - 9 posts
If that doesn't work then go into the monitor's menu and do a factory reset. ... it looks like those button get stuck and doesnt work anymore so this is the ... OSD lockout prevents the OSD menu from opening on the screen when ...
Jan 03, 2016 | HP 2010i Black 20" Widescreen LCD Monitor...
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Lg w2343t monitor
try monitor on a different working desktop to see if it works, both on the external and internal video card ports. If screen menu buttons fails to respond, fault is either on menu buttons or you may have a burned out lcd screen, try a different monitor on your desktop pc to check its functionality. Monitor probably needs replacement.( It might not be burned out for you mentioned "no signal" error message appeared on screen, have the screen menu buttons checked)
Dec 28, 2013 | Computers & Internet
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
Jul 08, 2010 | Summer Infant Day & Handheld Video...
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu+- and auto set buttons wont respond
Try unplugging it for 1-2 minutes & try again. If not & it's a crt monitor not lcd then toss it & buy a new monitor. If it's an lcd,check the maker's website for additional info.
May 12, 2010 | Computers & Internet
When I turn my monitor on a "Going to Sleep" message is displayed on a black screen and then the screen goes all black. We had a power outage acouple of nights ago and the pc was on. Since then our power...
It will be video cable or related.
Responding to prior post,
Fuses have nothing to do with the video proper.
If you have a message on the screen, which says the monitor is basically working or saying the fuses and inverter is working.
That message appears with lack of video, so it can be the cable itself, possibly the video card on the computer.
Dec 20, 2008 | HP Compaq 1501 15" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Black screen on LCD Monitor
There should be an problem with your power card or please change your monitor immedietely...
Jan 01, 2008 | AOC LM729 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
730 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
