Question about Gigabyte GA-6WMM7 Motherboard
BIOS problem need help I have a good pc GA-6WMM7 motherboard i try to upgrade the ram and hd. i get trouble on boot system. with new bios batt. i started to adjust day,time....then advanced=>advanced cmos setup and i presed inter then "VIEW DMI EVENT LOG" and stop even until next week.how can i exit from this type of .......... thank u mulugeta
  • 781 Answers
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
Posted on Aug 08, 2008
Usb didnot work
go to bios and then perapherical setting there check usb port is enable or disable
if disable enable it
if u wanna go to a bios press "delete" button at start ur system
Mar 07, 2010 | Gigabyte GA-6WMM7 Motherboard
Tip
Problems boot order on bios
my ga6wmm7 rev 1.5 boot order adjestment on bios not work only from flopy what can i do to boot from cdrom or hd? thank u
on Aug 02, 2008 | Gigabyte GA-6WMM7 Motherboard
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Can't boot after upgrade bios f6
If you flashed the BIOS and it stopped for whatever reason or you flashed the wrong BIOS version, there is nothing that you can do except to replace the BIOS IC.
  • If the system has a boot block to restore the original BIOS, use it. Refer to your motherboard documentation.
  • If not, you will need to contact the system or motherboard manufacturer for a replacement.
Mar 12, 2009 | Gigabyte 845pe (GA-8PE800PRO-R)...
Bios Failed During Bios Upgrade
pls check the RAM try re installing the RAM or try replacing them , may be it is a co incedent u thought it as a bios update failure pls check and reply back with mother board complete model number and manufacturer with processor details
and pls rate me if its helpful
Feb 24, 2009 | Gigabyte GA-K8NSC-939 Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Floppy cd rom or hard drive not recognised in bios
most probably the bios battery is week (that happened to me a few times on some old unused comps. ) ! Keep the computer pluged in for an hour or so ... and hopefully the next time u enter bios and set the booting devices, they will remain set 1
Mar 10, 2008 | Gigabyte GA-6WMM7 Motherboard
New system not booting
Check in the BIOS that your RAM and / or CPU speeds are correct or put them on auto. Choose Default BIOS settings first.
Aug 03, 2007 | Gigabyte GA-M61P-S3 Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Gigabyte GA-6WMM7 Motherboard Logo
326 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
