Question about Danby DPAC8099 Air Conditioner
Water tank is suddenly filling up
A few days ago, I noticed water dripping from the front of the Danby portable AC. Unfortunately, when I moved it, the water tank fell off the back snapping the connector off the tank (not damaging the AC unit). I propped the empty water tank under the back spout overnight (it was really hot and couldn't live without it) and when I woke up, the tank was almost full. I hooked up a short hose to it in case the water wouldn't leave the small opening without the water tank connector. In the three years I have owned it, it probably wouldn't fill it in the whole summer. Other than trying to replace the connector to the water tank (if I can), any ideas why it is leaking water and now filling up the water tank so fast? Thank you in advance!
  • 1 more comment
  • jmover52 Dec 29, 2008
    I also broke the connector for the larger tank that plugs into the back of the cooler. How can I get a replacement ?
  • Harry Kaz
    Harry Kaz Aug 09, 2014
    same with my Danby, first 2 years didn't need a tank at all. Then needed it. \Now mt every 2 days.
  • Harry Kaz
    Second Danby is 2 yrs old. No provision for tank, has drain plug at bottom. First two years worked fine, no have to move it out and drain every few hours.
  • 3 Answers
Call company for a connect piece
Posted on Jul 27, 2009
  • 958 Answers
Look closely how the water flows from the evaporator to the tank. does it goes first to the condenser ?..or is there a heating pipe that is touching the tank in order to heat the water for it to evaporate?
here's the set up, your ac would cool and absorb moisture in the air and becomes water in the evaporator. these water is sometimes used to cool the compressor or the condenser to help it run cooler and at the same time evaporates the un-needed water . but incase the water is so much then you have the tank to keep the water from spilling. sometimes they still put some hot pipes to further heat the water to evaporate.
check those pointers that i have mention.
in some case, the air in your place just got humid and wet that is why it has too many water condensation..
Posted on Aug 08, 2008
  • Harry Kaz
    mine is the same, first 3 years didn\t need the tank at all. Now it fills up every 2 days.
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
My Danby DPAC1010 Portable Air Conditioner is dehumidifying when simply in AC mode. I don't want it to, but if fills up a 2 gallon bucket every 2-3 days. I've had it overflow twice and I cannot...
The only way to stop it from dehumidifying is to stop it. A dehumidifier is a AC that is 'tuned poorly'. In your machine, while in dehumidify mode, you actually are running the AC in 'slow".
It is a law of physics. Warm air can hold moisture. Cold air can not hold moisture. When you remove the heat from the air, the water has to go somewhere, so it condenses on the coils and drips into the tank. Yes, that is true: Heat is a thing, you have to remove heat from the air. You don't simply "cool it", you remove the heat.
Your Danby should have a automatic shut off that comes into play when the condensate tank gets full. MY Danby, which is a sllightly different model than yours, has a connection that allows me to connect a hose that I lead to a floor drain to disponse of the condensate (water).
If yours is not equipped with a shut off nor a drain and you say it fills every 2 to 3 days, the options I see that you have is to dump it every day, or - don't run it all the time, or - turn the setting to a higher number which will reduce the AC and dehumidifying effect. On the down side of that, your humidity will remain high at the higher setting.
Thanks for your question @ FixYa.com and thanks for letting me assist you this evening.
Jun 29, 2011 | Heating & Cooling
I filled the tank on my 2000 Hyundai Elantra 4 days ago and the gage has not moved. I pulled out and checked all fuses previous (a few days) prior to me noticing the gage is not working. Is there a...
Put some carb cleaner in the tank.....The float on rour sending unit may be stuck......This will hapen on older vec when over fill.Hope this works for u.
Aug 12, 2010 | Hyundai Elantra Cars & Trucks
Reliance 501 - purchased house a few years ago don't know how old it is - water is dripping from bottom near plate can feel a small rectagular hole with what seems a small piece of metal in the middle -...
unfortunately not, if the tank is leaking from the casing, it needs to be replaced. i would suggest, if your not paying water tax, you can run the tank for as long as you like, just divert the leaking water into a floor drain. but i do highly recommend getting a new tank. that drip can turn into a flood in a matter of days, all depending how bad the inner wall has corroded.
Jun 20, 2010 | Water Heaters
Toiliet Drips in bowl for a while after you flush
Check flapper out and adjust water level in tank to proper level. If you get level right and it still does drip it sounds like the flapper is not sealing correctly to shut off water.
Toilet flappers are not to expensive and you can touch it with your hand and if you get a black residue off on your hands that a sign it needs replacing.
May 13, 2010 | Kallista Michael S Smith Loft One-Piece...
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
Drip pan overflow
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
Jun 18, 2008 | Kenmore 64702 Top Freezer Refrigerator
External water tank
Dear ziba1--posted the same problem two days ago and it doesn't appear to be on the site yet. Anyway, picked away at this again today (literally took the machine apart) and found the problem to be a clog in the drainage system. This explains why your external tank will not fill and why there is a leak--the drip tray under the compressor is not draining due to the clog in the drainage system. I fixed this simply by taking a narrow device and gently scraping out the drain hole of the drip tray (which is located just below the compressor...the compressor is located on the same side as your air filter). After successfully cleaning out this drain, I proceeded to flush the water out thoroughly with water. Give it a try--worked for me. I had all but given up and had already set up an appointment to have it serviced. Cheers
Jul 25, 2007 | Danby DPAC8399 Air Conditioner
Danby DPAC8099 Air Conditioner Logo
749 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
