Question about Frigidaire Affinity ATF7000E Front Load Washer
Is there a way to owerride automatic water level adjustment?
I have a Frigidaire Gallery, front loading machine.
It does not have a knob to select water level options. Product description states that the machine automatically adjusts water level depending on the load.
Well, I want this machine to use more water. Is there a way that i can switch this 'automatic' feature off, and just set the level manually once and for all?
Thank you, in advance.
Irina
  • 481 Answers
No, this is not an option with these types of washers.
Posted on Aug 08, 2008
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Adjust level water knob
Hi Leslie, great question! Since the knob is missing, it would have to be replaced and then installed. According to the post above, the model number for your washer is GLWS1339EC. If that's correct, you would need part number 134034902. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). To install the knob, align the back of the knob to the shaft and it should snap on. If for any reason you have difficulties you can use the service locator option on the manufacturer site to find a tech near you to further assist you. Thank you for allowing me to assist you.
Aug 17, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
Water leaking from the buttom
your washer is off balence its causing your tub from inside your washer to splash out on spin cycle adjust legs get a level then put on top[ washer see if its balanced then try a load.
Jan 26, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Hot water not going into washing machine
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
Water level
Your water level is adjusted automatically by the machine, you dont have any control over this. What yu need to see is to keep your wall faucet fully open before the wash, also check whether the pressure is good. It is normal that you see a low level thru your glass in machine............
Dec 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
