Question about Carrier Heating & Cooling
Carrier central air 38ckc060301 problem, unit will not start, air handling blower runs, can hear hum at outdoor unit. I turn the unit off at themostat. let sit for ten minutes, turn back on at themostat, unit starts and cools. Will run through serveral cycles and then not start until I repaet process, any thoughts?
solveditnow
  • 39 Answers
SOURCE: (HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Posted on Jan 08, 2009
Bat1956
  • 585 Answers
SOURCE: Central air conditioner will not turn on at all.
I understand this to be a heat pump. Check your thermostat settings, and the filters. And make sure a breaker isn't tripped.
Posted on May 21, 2009
  • 142 Answers
SOURCE: unit starts and stops to often
No this is not normal. You have a problem refered to as "short cycling". This is an indication of low refrigerant charge. You need to have the unit leak checked, repaired and recharged,
Posted on Jun 01, 2009
shastalaker7
  • 1515 Answers
SOURCE: carrier central unit outdoor unit will not
Hi, I would say to check for high voltage at the outdoor unit. You will have 24 volts from transformer on the secondary side of it, and high voltage on the primary side of the unit. @4volts are for all of the controls on the unit, contactor coil, all of the safetys, pressure switches high and low Ect. On a call for cooling, the stat sends power to the contactor coils, 24 volts to energize it and close the contacts and in turn starts the fan and compressor. Make sure you have high voltage at the unit. If not, check the main breaker, or the box mounted at the unit. Most will have 2 fuses in them that are behind a plastic cover. You can ohm them or just replace if your not sure. If you have power. If this is a split system central unit, check at the contactor for high voltage. If you have it, and it will not come on, you have to see if you are getting 24 volts to the contactor coil to pull in. If it does not, the problem is in the indoor unit unless this is a all in one outdoor unit. Please let me no, give me the details please.
Sincerely,
Shastalaker7
Posted on Apr 16, 2010
heatman101
  • 43501 Answers
SOURCE: my Carrier Home Central Air
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 11, 2010
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
Air conditioner starts up by itself
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Jun 01, 2011 | Carrier BCA101R Air Conditioner
Air conditioner will not turn on by remote green light keeps flasing and fan on outside box not working
Dec 15, 2010 | Carrier 36KCARMS Air Conditioner
Central A/C trouble in Las Vegas!
The contactor in the outdoor unit is stuck.You will need to replace the cooling contactor.I am sure it is wielded shut and thus will not turn off.
Sep 06, 2009 | Heating & Cooling
We have a new house and it came with central air. I have turned on the air and turned on the circuits and noticed that the outside fan on the outdoor unit was spinning round (good) now, I checked and the...
yes indeed Id have to say the motor hasent been oiled....call a hvac guy and see how much theyd charge ya for maintenance call and decide then as if its priced right for you. after the inspection he'll tell you "XXXX" is wrong and you need this or that.
Jun 23, 2009 | Heating & Cooling
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Heating & Cooling Logo
186 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
