LG L1915S 19" LCD Monitor
Problem for LG L1915S 19" LCD Monitor
Making new TFT work
By Chandler - usenet poster
Hi all,
Have got a new TFT to replace ageing iiyama VMpro400. Graphics card is set
to 1024x  and 85hz refresh and plugging in the TFT results in it showing a
"signal out of range" message and blank screen.
Plugging it into my server PC it works fine.
Should I lower the refresh rate and remove the iiyama monitor.inf file in
control panel > system and reboot so windows uses a default monitor or what?
Want to check before I screw up working PC!
(There is no monitor driver on the TFT CD- just lots of read me and pdf's
from what I can see)
Tim..
Best Solution
posted on Aug 11, 2005
Very Helpful)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Only in so much as faster response time for games will be better, it is
not a strict comparison - just that for TFT response time *does* matter.
Yes - irrelevent for most typical business use.
Yes, TFTs with slow response time when displaying fast moving images
may end up blurring - recall early DSTN displays on document "page down".
Dorothy Bradbury
Was this helpful?
Yes
No
Solution #2
Not Rated)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
My TFT (samsung 710V) gives me blurred "bars" down the screen at anything
below 72hz :S
Was this helpful?
Yes
No
Solution #3
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
In <fsidnVNfM6RJCyLcRVn @eclipse.net.uk>,
That sounds like the effect of getting the pitch setting wrong, it'll
just be coincidence that it gets it right at the higher frequencies.
Check the monitor's OSD menus. This may help for "tuning", make sure you
display it at 100% scale:
<http://www.realh.co.uk/lcdtest .gif>
The address in the Reply-To is genuine and should not be edited.
See <http://www.realh.co.uk/contact .html> for more reliable contact addresses.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
"Dorothy Bradbury" <dorothy.bradb @ntlworld.com> wrote in news:jWMvd.1410
$cM5.1 @newsfe6-win.ntli.net:
Does it follow that 16ms ~ 62.5Hz
and 14ms ~ 71.4 Hz
And this kind of comparison is only remotely useful for fast changing
images.
(for static images (eg reading text) it is more or less irrelevant,
cant beat a TFT for reading static text except with pen and paper)
 And the issue, rather than lack of persistence, is too much of it,
Lordy
Was this helpful?
Yes
No
Solution #5
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
Most 15" TFT run at 1024x768 native.
AZC
Was this helpful?
Yes
No
Solution #6
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
Games tend to involve action initiated in the peripheral vision.
o The peripheral vision is more susceptible to flicker
---- if you view a traditional CRT TV head-on it does not flicker
---- view it sideways on in your peripheral vision & it may flicker
o The point at which flicker is not detected is termed fusion
---- the critical fusion frequency (CFF) is generally 67Hz for most people
---- most people means a distribution, some need less Hz, some more
Whilst CFF is generally 67Hz it has been shown that reading performance
can benefit from frequencies >85Hz and in some cases >110Hz or higher.
Whilst games don't involve much in the way of reading re saccadic
movement, they do involve a lot of peripheral vision processing. The
peripheral vision is still heavily involved in low-level cognitive fight
or flight reaction programming - so may be frequency sensitive.
o For a CRT displaying both text & games refresh frequency matters
---- 85Hz is a typical minimum, not difficult on modern CRTs
o For a TFT displaying text, refresh frequency nor response time matter
---- exception potentially being on scrolling text re reading/searching
---- however we are a long way on from slow DSTN TFT (v Active TFT)
o For a TFT displaying games response time matters
---- that will probably have a direct impact on cognition/vision
---- a TFT with a response time of 20ms is potentially 50Hz
So whilst setting a higher refresh on a TFT doesn't do much, picking
a TFT with low response time for dynamic tasks can be very important.
Dorothy Bradbury
Was this helpful?
Yes
No
Solution #7
Not Rated)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
"GSV Three Minds in a Can" <G @quik.clara.co.uk> wrote in message
High framerates in most games mean faster response to input, even if you
can't see the resulting change. I think it's more teenage reactions than
teenage eyes.
Alex
Was this helpful?
Yes
No
Solution #8
Not Rated)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
Try and find an LG and an Acer with identical spec on the same shopping
site, the more expensive of the two will most likely be the rebranded one.
Was this helpful?
Yes
No
Solution #9
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
Bitstring <cpmn1u$9b @newsg3.svr.pol.co.uk>, from the wonderful person
Morgan <mor @home.net> said
It's still the rate at which the screen gets completely re-written, but
with a TFT you didn't need to re-write the screen (since it's basically
static) unless it changed. Some people with teenage eyes seem to think
they can detect 100 FPS or even higher .. me, I just get bugged if I can
see the flicker, which with a decent TFT/CRT I can't, even at fairly low
refresh rates.
Outgoing Msgs are Turing Tested,and indistinguishable from human typing.
Was this helpful?
Yes
No
Solution #10
Not Rated)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
Hi all, I set windows to "default monitor at 1280x1024 at 60hz", plugged it
in and i'm typing on itnow! Yerrha.
I'd recommend the Acer AL1912s to anyone, excellant value for money, and
cant see a dead / stuck pixel on it anywhere.
Tim..
Was this helpful?
Yes
No
Solution #11
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
I wonder if that is the rebadged LG monitor that I have....
http://www.microdirect.co.uk/p roductinfo.aspx?productID=7820
...unless mine could be a rebadged Acer...!!!
Regards
Morgan
Hard drive problems...
www.flyinglizard.freeserve.co. uk
Was this helpful?
Yes
No
Solution #12
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Cheers guys i'll try that- it is an Acer 19" L1915s actually!
Tim..
Was this helpful?
Yes
No
Solution #13
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
On the two TFT's that I have they both run at 1280x1024 at 60Hz but I have
noticed that one of them (LG 19" L1915s) will also support 75Hz, even though
60Hz is recommended.
Understanding that TFT's don't have to "refresh" as the CRT screens do what
does the 60Hz or 75Hz refresh rate actually mean with a TFT, do you know...?
Regards
Morgan
Was this helpful?
Yes
No
Solution #14
Not Rated)
Melissa
Rank: Apprentice
Rating: 0%, 0 votes
In <cpmn1u$9b @newsg3.svr.pol.co.uk>,
It's fairly meaningless for TFTs, I think they just allow a range of
frequencies to make them more flexible. The advantage of 75Hz is that
you may get higher FPS in games, or smoother video playback, if they're
set to sync with the monitor refresh. Should be negligible though. The
disadvantage is that it will be nearer the monitor circuitry's bandwidth
limit, so quality may degrade slightly, especially with an analogue
connection.
Was this helpful?
Yes
No
Solution #15
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
know...?
Nope, not a clue.  I've just checked this one (Dell 17" TFT) and can set
that to 75Hz, too, but absolutely no visible difference..
Good that you mentioned the res. - all 15",17" and 19" TFTs I've used
run natively at 1280x1024, so OP should probably use those settings if
changing refresh rate doesn't help.
HTH
Rob
Was this helpful?
Yes
No
Solution #16
Not Rated)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
" Tim (Remove NOSPAM." <the.f @NOSPAMbtinternet.com> wrote in message
Yes, refresh speed should be 60Hz for most TFT displays, so either
reduce it to that or install as 'default monitor'.
HTH
Rob
Was this helpful?
Yes
No
Popular Solutions for LG L1915S 19" LCD Monitor
Questions and Unsolved Problems for LG L1915S 19" LCD Monitor
Do you recommend LG L1915S 19" LCD Monitor?
Answer
Answer
on the desktop i m having vertical column on the left most having the icons as well
Answer
when i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop,... (More)
Answer
my 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this... (More)
Answer
what value does R106 have. Since mine is burnt out I need to replace it
Answer
vertical line in the left side of the screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG L1915S 19" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
