Question about Hitachi 43FWX20B 43" Rear Projection Television
Hitachi 43fwx20B Same red blurry issue that everyone is having. After I run magic focus it get stuck on the red and stops. A number 5 appears on the lower right corner of the screen. Do you know what that means? A code of some sort?
  • technique Aug 24, 2008
    I do have the same problem. Magic focus started and suddenly jam on color red a few seconds and the number 5 appears at the right bottom of the screen. Then there's always red flickering lines in the picture.
    How much STK392-150 chip do I have to buy? Is it easy to fix?
  • Anonymous Sep 25, 2008
    it stops on the green not red and a number 5
  • 927 Answers
Good Day, firstshot;
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Good Luck, big IRISH.
Posted on Aug 16, 2008
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Magic Focus error green 5.
Here's a link to perform a DCAM convergence on your television and reset your magic focus. Instructions for the S series are halfway down but be sure to read the whole page. Best of luck.
Greg
http://www.hdtvoice.com/voice/showthread.php?t=3736
Jun 11, 2009 | Hitachi 51G500 51" Rear Projection...
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Blurry picture
can you be more specific? magic focus doesn't fix etc etc?
Jun 02, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Horizontal hour glass picture
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Dec 16, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
170 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
