Scanners
Problem for Scanners
Generic problem for all Scanners
Acrobat 6.0 Professional Doesn't Rec...
By billbarnett on Aug 08, 2008
We're running Windows XP, Acrobat 6.0 Pro, and an HP Scanjet 4570C scanner. When we try to create a PDF file from scanner, the software does not recognize that the scanner is installed. We are prompted to re-install the HP software. The HP software was re-installed and still the problem occurs. The HP software is HP Photo and Imaging Software version 1.1 for Windows XP.
Is there a trick or tip to getting this scanner to work?
Same deal: can't access the scanner from within Acrobat 6 & Paper Port 9 Office. But I can access the scanner from Photo Shop and a fax program. The problem just showed up with no changes to anything I can recall. I've uninstalled/reinstalle the scanner and scanner software several times along with Acrobat 6. I'm using the work around that several others have figured out: scan with the scanner software and move to the appropreate location. Very strange problem indeed.
Same Problem
Jan 02, 2009
-   Acrobat 6.0.6 quit working with my HP ScanJet 5P (which uses a SCSI card). It just quit recognizing the scanner but other applications like MS Document Imaging work fine. I un-installed and re-installed Acrobat 6 plus I replaced the scanner with a CanoScan 5600F but no-joy. Acrobat still will not create a PDF with the scanner. I've done everything I can think of except re-install Windows XP Pro.-   Guest
Popular Solutions for Scanners
Questions and Unsolved Problems for Scanners
Answer
I need a hendheld pen scan suitable for XP and editable on word, to save especially half of the... (More)
Answer
Officially my scanner, a visioneer strobe XP 200, is not ''supported'' anymore on Windows 7. Is... (More)
Answer
I need to use my scanner with windows xp. can you help locate a suitable driver for me, please?
Answer
I have a C6300 HP printer/scanner. Great machine, however when I scan a document it only shows me a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Scanners:
Top Scanner Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
