Question about Jenn-Air 25.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Filtered Ice & Water
Jenn Air model JCB2388AR, about 11 years old
The inside of the refrigerator door where the shelf/bins fit in place is too large to adequately secure the bins and they fall out. It is as if the plastic in the door is bowed and the bins are too narrow to fit well causing the bins to fall on the floor. I have had to take the bins off the door because of the many times they have fallen and things have broken. Is it possible to purchase the whole inside of the door? This has been present almost since the beginning.
We got heavy duty velcro and put it on the back of the bins. Works like a charm
Posted on Sep 06, 2010
Frozen food in refrigerator
Can you confirm your model number? I see what says that your model is a JFC2089HE above your post but knowing Fixya the model number there is automatically placed there and is most times incorrect, Thanks John Tripp Appliance 911
Feb 18, 2014 | Jenn-Air JFC2089HE French Door...
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf - http://www.appliancepartspros.com/Appliance-Parts/frigidaire-bin---door-frzr---upper-item-number-ap2115843.aspx
  2. This one is a replacement for the lower 3 freezer shelves http://www.appliancepartspros.com/Appliance-Parts/frigidaire-freezer-door-shelf-item-number-ap2115974.aspx
  3. This one is a replacement for the 2 bottom shelves of you refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2115741.aspx
  4. This part here is for the 2 upper shelves of your refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2116036.aspx
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
We have a subzero 201R and I need a door shelf replacement
subzero number 1800 222 78 20. EXCELLENT CUSTOMER SERVICE. depends in what part of the usa.they have information for your close store
Aug 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Whirlpool Refrigerator Shelf falling off support pins regularly
I got a new refrigerator that has the same problem. I solved it by cutting a triangular pencil grip for children's pencils down so they extend out just past the pegs on both sides (making them longer). The grips fit on snug, just like on a pencil, you don't have to screw the shelves in permanently which allows them to be taken off and moved. Works like a charm and holds the shelves in very snug.
PAM
Dec 17, 2008 | Refrigerators
Shelf locators broken of the back the freezer on kelvinator impression series 500l
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Oct 17, 2008 | Refrigerators
Maytag refrigerator door wont close
If your door seal is seating flush all the way around the opening and there are no obvious gaps, the door seal does not need to be replaced. It could be related to a hinge or something inside the unit not letting the door close entirely.
Oct 04, 2007 | Refrigerators
Refrigerators Logo
136 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
