Question about Magellan Meridian Gold GPS Receiver
Deprogramed Put a sd card that was formated for camera and lost everthing wil power up but will not go any futher.
  • kg4vny Aug 08, 2008
    it is a meridian gold
  • 3 Answers
I need more info to possibly help.
Do you have info on the SD card you need to keep?(just use a SD card reader for your computer to reformat to FAT) Be sure to copy all files to a safe place FIRST!
You could also try this combination, to clear ALL memory then reboot GPS unit.
1. Press and hold "Enter"+"Menu"+"PWR"
2. Follow GPS units On-Screen directions.
If GPS unit "locks-up" press and hold keys in this order, "Goto"+"ESC"+"Enter".(Forces GPS unit Off)
good luck
Posted on Nov 02, 2008
How do I recover pictures back to my power shot sd card
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
Sep 23, 2014 | Canon Powershot Power Shot A70 A 70 3.2 Mp...
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
I have a JVC 20 GB camcorder. Model GZ-MG2-1U. Before I tried to install an 8MB SD I selected on the menu to protect all. I turned the camera off, installed the SD card, turned the power on and then I...
There should not be anything to install when inserting an SD card, all you do is put the card in the card slot. If you tell it to format you have to go into the menu first and tell the camera which you are referring to the card or the harddrive. If you didnt change the setting to SD card when you did give it the format command than that is why your data was lost. If you are having an SD card error make sure that the little slide switch on the card is set as not to protect the card that will give the error sometimes. I hope this helps
Sep 15, 2010 | JVC Video Cameras
Formatted a 2GB sandisk card in my camera. Lost
If you have an sd slot in your computer you can plug the card into sd slot start/computer/right click removable hard drive disk for sd card format
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Formatting-Lost Pictures
hi
just data recovery softwar like get databack
u wil get 100% recovery from formeted card
Apr 17, 2009 | Cameras
Virus on sd card
If your pc tells you the sd card is infected it means you have an AntiVirus running. You can use it to remove the virus by SCANNING the card.
You can also get rid of the virus by FORMATTING the card using the camera. The Format option (NOT EARASE) is usualy found in the settings menu. But beware, you will lose all the pictures as well.
Feb 08, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Magellan Meridian Gold GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
