How do you turn of external speaker - Computers & Internet
    Sergeant:
    Champion:
  • 246 Answers
Normally there is a power of switch with any kind of external speaker . Because external speakers have to supply power from the main current not form the computer.
Posted on Aug 08, 2008
How do I connect conventional speakers to Alexa?
  1. Set your Echo Dot and external speaker at least three feet apart. When Echo Dot is close to external speakers, it may be more difficult for Alexa to hear the wake word and other requests.
  2. Turn your external speaker on.
  3. Plug one end of an audio cable into your speaker and the other end into Echo Dot. All audio from Echo Dot now streams through your external speaker.
May 21, 2017 | Computers & Internet
I plugged in external speakers but get no sound. Is there somewhere in a menu to turn the speaker ports "on"?
In almost all the led tvs there is an option in the menu to select whether you wish to use internal speaker or the external speaker. You have to make the after putting an external speaker.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Televison & Video
How do I get external speakers to come on?
You can select the option at its sound menu. Get it, and select 'External speakers' which in turn switch off the internal speaker, and bypass the signal to the external speaker. But; the you can't bypass the audio output, but the audio signal output from the back of the TV to any external amplifier or so. If you've any doubt, contact any technician. Gopakumar Gopalan Google
Sep 16, 2014 | Samsung LN46A650 46 in. LCD HDTV
Do internal speakers need to be off for external speakers to work
I have found in some instances my external speakers need to be off. Mostly if I use my smart TV on Netflix or Amazon Prime. If you have external speakers attached it is better to turn off internal speakers.
Feb 05, 2013 | GE 35GT740 35" TV
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
Want to install exterior speakers
Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
Jun 04, 2010 | Westinghouse LTV-19w6 Television
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Speaker creative sbs340
check control panel, and see if sound is configured for your external speakers. Some screwup may have occured, leaving your computer speakers turned off, and your external speakers not comfigured.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
