Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
The coffee grinder and brew starts on it's own. Saeco Decanto Serius
  • 515 Answers
Try to take off the top, then the front panel (four screw) on the backside of the panel you will see two printed circuit card, make sure this is tight to the panel.
Put all in place again and test your machine, if there still is problem then i think you have to replace the touch panel on your machine.
Posted on Aug 08, 2008
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
Grinder won't stop
Hi
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
81 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
